MCSP and ICD2 Microchip
Results 1 to 7 of 7
    @f5bqp Not yet but i use a lot of serout for debugging at the moment
    @bbazor thats for the Epic not Microchip ICD2
    Nope that's not for EPIC Either, it's for Mecanique MicroCodeStudio ICD. I no longer have an ICD-2 but from what i remind you have to include a specific header. These can be found in in PBP folder (ICDDEFSx.BAS). MPLAB.txt tell you how to use it.
    Thank you mister_e, i'm using a ICD2 clone now.
    ICD2 Clone
    I will try to use In circuit debug with this one i let it know.
    ICD2 works great as a debugger tool with ASM code from within MPLAB. Besides it was designed for this purpose. You cannot debug at PicBasic level your code because it is compiled and the produced asm file has nothing to do with the commands in Basic.
    On the other hand the Microcode ICD can debug your Basic code by inserting extra commands (increasing the size of your hex code...) and displaying the variables you want on screen through serial connection. This means that your PIC must have USART and dedicate this 2 pins Tx and Rx to the Debuger.
