Command to Clock Cycle table
Results 1 to 2 of 2
    blainecf's Avatar
    blainecf Guest
    Question Command to Clock Cycle table
    Does anyone have a cross-reference table for PBP commands to the # of clock cycles needed to execute that command?
    Would be useful in timing critical situations to know which commands to use / stay away from.
    Thanks!
    bcf
    none exist and there's a good reason for. How many different way you can write and IF THEN ELSE? FOR TO NEXT? WHile/WEND and so on?
    you can use different methos to measure it, toggle a led before and after a statement block and measure it with a scope.
    Start a timer before, stop it at the end, calculate the amount of tick then send it over serial to your pc or on a lcd.
    Use MPLAB stopwatch
    list is long...
    EDIT: there's something to play with... say thanks to Darrel
    http://www.picbasic.co.uk/forum/show...ighlight=cycle
  1. EM4095 Chip, get Clock and Data signals?
    By mindthomas in forum mel PIC BASIC Pro
    Last Post: - 19th August 2008, 06:27
  2. PICBasic newbie problem
    Last Post: - 12th February 2008, 00:55
  3. Shiftout/in
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2007, 11:48
  4. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 20:36
  5. Interrupt cycle time limitation?
    By jswayze in forum mel PIC BASIC Pro
    Last Post: - 24th March 2005, 07:11
