Storing Text in EEPROM - ideas wanted
Results 1 to 8 of 8
    Jun 2005
    Wisconsin
    Before we get too far, are you using internal EEProm or External? What type of pic are you using?
    If its internal take a look at the DATA, and READ commands. These in combination with with a for/next loop should give you what you are looking for. The reason for 0 is as you are reading data from EEProm when you read 0 that tells the loop to stop and exit.
    If External what type is it, I2C?
    Aug 2005
    I am using the internal eeprom on a 16f628a / 648a
    Jun 2005
    Wisconsin
    To add your strings via the DATA command:
    DATA $00,"Switch01",0
    Example of reading the above and displaying it on an lcd:
    For CounterA = 0 to 16
    Read CounterA,value
    If CounterA=0 then goto Main
    LCDOUT value
    Next CounterA
    This should be enough to get you started.
    Aug 2005
    Ok,
    Ive got this far:
    INCLUDE "modedefs.bas"		' Modes for SerOut
    CMCON = 7					' set portA to digital
    TRISA = %00100000			' Port A all output but MCLR
    TRISB = %00001010			' Port B all output but 1,3 (Si and CCP)
    DEFINE DEBUGIN_REG PORTB		' Set Debug pin port
    DEFINE DEBUGIN_BIT 1			' Set Debug pin bit
    DEFINE DEBUGIN_BAUD 9600		' Set Debug baud rate
    DEFINE DEBUGIN_MODE 1			' Set Debug mode: 0 = true, 1 = inverted
    DEFINE DEBUG_REG PORTB			' Set Debug pin port
    DEFINE DEBUG_BIT 2				' Set Debug pin bit
    DEFINE DEBUG_BAUD 9600			' Set Debug baud rate
    DEFINE DEBUG_MODE 1				' Set Debug mode: 0 = true, 1 = inverted
    port1name  var byte[8]
    name1		var word
    i var byte
    Main: ' Display "Waiting for input" every 5 seconds if timeout period expires
        	DEBUGIN 5000, idle, [STR port1name\8\13]
    	  	DEBUG "Received: ",STR  port1name\8,13,10
    for i = 1 to 8
    	write i,port1name(i)
    	pause 10
    next i
    for i = 1 to 8
    	read i, port1name(i)
    next i
    DEBUG "Read eeprom after write: ",STR  port1name\8,13,10
    Goto Main
    idle:
    DEBUG "Waiting for input",13,10
    for i = 1 to 8
    next i
    DEBUG "Read from eeprom: ",STR  port1name\8,13,10
    Now, it receives what i enter, and saves it, and displays it fine, however once power is cycled, and it reads from the eeprom, the 1st character is incorrect:
    Received: 12345678
    Read eeprom after write: 12345678
    Waiting for input
    then power cycle
    then i get this:
    Waiting for input
    Read from eeprom: û2345678
    any hints on what i may be doing wrong?
    Also all comms is serial @ 9600, there is no LCD, therefore the LCDout command cant be used....
    Jun 2005
    Wisconsin
    When you said "I want to be able to label (name) the inputs on the status display" I thought you were talking about an LCD.
    When you use the STR command you are starting at 0 not 1.
    Try this instead
    for i = 0 to 7
    read i, port1name[i]
    next i
    AND
    for i = 0 to 7
    write i, port1name[i]
    next i
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. How to define constants that specify eeprom addresses
    By DwayneR in forum mel PIC BASIC Pro
    Last Post: - 8th December 2009, 04:07
  3. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
