bankA issues
Results 1 to 7 of 7
Thread: bankA issues
    Sep 2005
    Campbell, CA
    Default bankA issues
    Ok, now I have Darrel Taylor's "Instant Interrupts" running, with PBP and assembly interrupts.
    Now, I find that I need yet another assembly-language routine (not interrupt-driven) to calculate an internet checksum (I need a 24-bit counter).
    I have been putting all the assembly-language variables in bankA - which is now full. My assembly ISRs have some temporary variables that PBP doesn't read or write to, but on the advice of people smarter than me, I have those located in bankA as well.
    My question is - Is it safe to not declare the variables "local" to the assembly language program as "bankA"? Can anybody give me some advice as to how to either free up some of the bankA space, or tell me it is OK to put my assembly-local variables in "not bankA"?
    Charles Linquist
    Hi again Charles,
    Glad you got it working, and ...
    it is OK to put your assembly-local variables in "not bankA"
    In this code, V24 could be located in any bank, and you don't know where it is.
    CHK?RP will switch to the proper bank for you. Then it's the same as if it were in BANKA.
    V24   VAR  BYTE[3]       ; 24-bit variable
    ASM                      ; 24-bit counter
        CHK?RP    _V24
        incfsz    _V24, F
        goto      NoCarry
        incfsz    _V24 + 1, F
        goto      NoCarry
        incfsz    _V24 + 2, F
    NoCarry
    Sep 2005
    Campbell, CA
    So, I think you are saying
    _V24 could be anywhere in memory, and the CHK?RP macro will switch
    to that bank and allow the routine to execute properly.
    But as a hypothetical question -
    If I needed to read the value of V24 later in my (PBP) program, would I have to copy the value of _V24 into another variable that was defined as 'bankA' in order to allow my PBP program to find it? And would the same be true if I wanted to pass a variable from PBP TO an assembly routine?
    Charles Linquist
    Correct!
    But, the variable is defined in PBP. Therefore, it's always accessable in PBP.
    Of course, PBP can't handle 24-bit variables directly. But the array can be used like normal...
    x = V24(y)
    May 2006
    Del Rio, TX, USA
    Darrel,
    Shouldn't the ASM intructions include the memory access bit=1, as indicated by the bold changes, so that the command uses the bank selected by BSR rather than the access bank?
        CHK?RP    _V24
        incfsz    _V24, F, 1
        goto      NoCarry
        incfsz    _V24 + 1, F, 1
        goto      NoCarry
        incfsz    _V24 + 2, F, 1
    May 2006
    Del Rio, TX, USA
    Quote Originally Posted by SteveB
    I’m responding to my own post/question. This will save Darrel the trouble and may help others.
    After more careful examination of the datasheets, it looks like the default values for ‘d’ and ‘a’ are 1 for most of the 18F instructions. This is not clearly listed in “Complete PIC18 Reference Manual,” but was listed in the 18F4620 datasheet, so I missed it on first inspection. That being said, it appears that the previously listed code could be simply:
        CHK?RP    _V24
        incfsz    _V24
        goto      NoCarry
        incfsz    _V24 + 1
        goto      NoCarry
        incfsz    _V24 + 2
    This would default to saving the result back to the _V24, and using BSR to select the bank. Haven't checked ALL the instructions that use these bits, nor ALL the 18Fs, so YMMV.
    EDIT: I also found this note in the datasheet:
    Note: If the register is specified with the full 12-bit address, the assembler will automatically force the access bit to a ’0’ (when the address is in the access RAM area) or a ’1’ (for all other addresses).
    I hope everybody doesn't start answering their own questions.
    Nice job though! &nbsp;
  1. Instant Interrupts - Revisited
    Last Post: - 17th February 2016, 23:14
  2. USB with 20 pins anyone? PIC18F14K50 issues
    By ScaleRobotics in forum USB
    Last Post: - 17th July 2009, 16:39
  3. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  4. calibration clock 12f508
    By volcane in forum mel PIC BASIC Pro
    Last Post: - 5th December 2006, 11:33
  5. Still HSEROUT woes
    Last Post: - 11th July 2006, 22:13
