16f628 supply voltage 3.3v
Results 1 to 9 of 9
    Feb 2005
    GREECE
    Question 16f628 supply voltage 3.3v
    Hello to everybody,
    I have a question.The datasheet of the 16f628 claims that the operation voltage range is 3.0v-5.5v.
    I try to supply with 3.3v but it is dead.It starts working from 4.5V.
    Do I need to set it so as to start from lower voltage.
    Thnks in advance
    Nikos Geronikolos
    Set config fuse BOD "brown-out detect" to off to disable brown-out detection.
    Look in the Electrical Specifications section of your data sheet for Brown-Out
    Detect Voltage for an explanation.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    Feb 2005
    GREECE
    Thanks Bruce,
    I have just turn the brown-out detect to OFF.
    All is playing nowwwww.
    Thanks again.
    Feb 2005
    GREECE
    Question
    Bruce an other one question.
    Do you have any idea how I one pic will read an ASCII from an other and send to a pc.
    What I mean is:
    1st pic:
    SerOUT portb.5,N2400,["ID:001 TYPE:A"] <----
    2st pic:
    SerIN portb.0,N2400,SerialData
    hserout [SerialData]
    My pc terminal is receiving $#%#$@^%$^
    Please advice
    Have you verified your PIC sending data to the PC works?
    What happens if you send HSEROUT ["Hell World..!"]?
    Also your sending 13 bytes from PIC #1, but only receiving "1" byte at PIC #2.
    Look at using SERIN2 with the string modifier.
    -Bruce
    tech at rentron.com
    yourmomOS's Avatar
    yourmomOS Guest
    Default did you try this?
    create an array in the second pic
    X var byte
    X = 15
    serialData var byte[X] <- or however long the data is
    1st pic:
    SerOUT portb.5,N2400,["ID:001 TYPE:A"] <---- your outputting ascii
    2st pic:
    SerIN portb.0,N2400,SerialData <----your receiving the ascii number rep...
    hserout [STR SerialData\X] <---declare tht it is a string your outputting
    That should work but I didnt try it.
    SerIN portb.0,N2400,SerialData is only going to receive a single byte of data.
    Assuming you had a 13 byte array, I.E. SerialData VAR BYTE(13), then the
    above would receive a single byte in SerialData(0).
    The name of any array is simply a pointer to the starting address of the array
    in RAM.
    SERIN2 portb.0,16780,[STR SerialData\13] would receive all 13 bytes.
    -Bruce
    tech at rentron.com
    Feb 2005
    GREECE
    Bruce,
    I can talk with my PC using HSEROUT of the 2st pic.That is ok.
    I try to use thje followings wityh no success:
    1st pic:
    2st pic:
    hserout [STR SerialData\13]
    1st pic:
    SerOUT2 portb.5,N2400,["ID:001 TYPE:A"] <----
    2st pic:
    SerIN2 portb.0,N2400, [STR SerialData\13]
    Nothing is playing of the following
    Please advice
    Try changing these;
    To this;
    SerOUT2 portb.5,16780,["ID:001 TYPE:A"] <----
    SerIN2 portb.0,16780, [STR SerialData\13]
    Does it work now?
    -Bruce
    tech at rentron.com
  1. Crystal oscillator tied to supply voltage?
    By achilles03 in forum mel PIC BASIC Pro
    Last Post: - 27th March 2009, 17:28
  2. Battery charger - power supply issue affecting ADC
    Last Post: - 14th December 2008, 00:12
  3. Expanded Scale Voltmeter
    By Pic_User in forum Schematics
    Last Post: - 8th February 2008, 20:32
  4. MAX133 Interface to PIC16F877, how to?
    By phreakerzoid in forum Off Topic
    Last Post: - 14th June 2007, 13:58
  5. Help with final project
    By OvERKiLL in forum General
    Last Post: - 15th December 2006, 20:35
