RF Module
Results 1 to 23 of 23
Thread: RF Module
    Jun 2006
    Bangalore, India
    Question Low capacitance Transistor
    Does anyone know any replacement for MPSH34 transistor ???
    It should have very low capacitance...
    Iran
    it's really hard to make a RF transmitter and reciever . it's need a lot of experience. i think the best way is using modules, for example U2741B and U3741BM from atmel or you can use TXC1 and RXD1 from keymark company.(TXc1 and RXD1 are ready made devices). In your frequency(433.92MHZ), you should use SMD devices.
    if you need more information ask me again.
    Sep 2003
    INDIA
    Default Maybe I can help you !
    Hi shahidali,
    I can help you with a design which you can do it yourself using MICRF 007 (RX) and MICRF 102 (TX). I have the chipset and the required crystal for you to go on 433 Mhz. I can also supply you with the PCB's for the project if you need, Some minor SMD parts you will have to organize from Bangalore.
    Surely you must know or have some experience in soldering SMD parts on the PCB.
    I am from Mumbai and if interested you can PM. Also if you are interested I can supply some advanced design (ready modules) using CC1100 and CC1000 chipset, but then you will require some sort of programing experience for these.
    regards
    Charudatt
    p.s.: Rx made using 007 chipset from MICREL is the worlds simplest design for 433Mhz.
    Hi Charudatt,
    Are the Micrel parts available in Mumbai?
    Anand
    I don't know where Mumbai is but you could have a look at their distributor list
    http://www.micrel.com/globalmap.do
    Jan 2007
    maybe it possible to use any FM transmitter but modify mic input to tone generator from pic, and as receiver use small fm radio + tone to digital converter.
    or just use any r/c toy
  1. Interfacing 16F88 to RF module
    By scomi85 in forum General
    Last Post: - 19th February 2009, 13:52
  2. problem with sending data using RF module
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 10th April 2008, 18:08
  3. Rf module
    By tangray in forum Adverts
    Last Post: - 7th August 2006, 08:14
  4. LINX RF module and PIC
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 18th January 2006, 23:44
  5. Interfacting RF Module
    By rastan in forum General
    Last Post: - 10th November 2004, 23:27
