RF Module
Results 1 to 23 of 23
Thread: RF Module
    Jun 2006
    Bangalore, India
    Exclamation
    I finally found something on google that looks real easy to make.
    Can someone tell me if these circuits will work and what range they might have?
    http://www.cappels.org/dproj/LCRFLIN...tr/TRFxmtr.htm
    http://www.cappels.org/dproj/LCRFLIN...rF/TRFrcvr.htm
    Jun 2006
    Bangalore, India
    Arrow ???
    Has anyone got any other ideas???
    I just need a simple circuit that is capable of transmitting and recieving data.
    Range - 25 to 30 metres...
    Frequency - Anything . . .
    Dec 2005
    Shahidali, as you seem to want to build one yourself instead of buying ready made devices, the final result and performance will very much depend on your build quality and the quality of components you use and the antenna you employ at both the transmitter and receiver and also the frequency you end up operating on. Since the inductor will be constructed by you, I emphasise build quality. So, why not try building some of the many circuits you now have acquired (including some you've found yourself), then come back and tell us how you've done and how well they have performed. However, without some good test equipment, or alternatively at least a tuneable receiver in the frequency band of your transmitter, you will have a hard time achieving a measure of success whilst working in the dark, as you won't even know what transmit frequency your construction has ended up with.
    Wink
    A link to visit : http://www-k.ext.ti.com/srvs/cgi-bin/webcgi.exe?Company={5761bcd8-11f5-4e08-84e0-8167176a4ed9},kb=analog,case=obj(4270),new
    Jun 2006
    Bangalore, India
    Question Low capacitance Transistor
    Does anyone know any replacement for MPSH34 transistor ???
    It should have very low capacitance...
    Iran
    it's really hard to make a RF transmitter and reciever . it's need a lot of experience. i think the best way is using modules, for example U2741B and U3741BM from atmel or you can use TXC1 and RXD1 from keymark company.(TXc1 and RXD1 are ready made devices). In your frequency(433.92MHZ), you should use SMD devices.
    if you need more information ask me again.
  1. Interfacing 16F88 to RF module
    By scomi85 in forum General
    Last Post: - 19th February 2009, 12:52
  2. problem with sending data using RF module
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 10th April 2008, 17:08
  3. Rf module
    By tangray in forum Adverts
    Last Post: - 7th August 2006, 07:14
  4. LINX RF module and PIC
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 18th January 2006, 22:44
  5. Interfacting RF Module
    By rastan in forum General
    Last Post: - 10th November 2004, 22:27
