RF Module
Results 1 to 23 of 23
Thread: RF Module
    Jun 2006
    Bangalore, India
    Exclamation
    Hello dhouston,
    The file you posted (UR19A.PDF) has a nice transmitter schematic.
    But, the complete details of L1 are not given.
    Do you have a reciever schematic for this transmitter ???
    Dec 2005
    Quote Originally Posted by shahidali55
    Hello dhouston,
    L1 is a circuit board trace that acts as the antenna. If you're going to build something, build the one in the http://jap.hu/electronic/rf/el9805.pdf link.
    X-10's RR501 used almost exactly the same circuit as the Ming receiver for which you found a schematic. Or, you can do a Google search on "RR501 Orysh schematic".
    The RF1 transmitter and receivers shown on the site cited by ra68gi http://www.modielectronics.com/RFPG_1.htm are the ones made by Wen Shing (or are clones thereof) that I mentioned earlier. You cannot go wrong with them.
    OOOPS! The RF modules in both links from ra68gi are from HiMark (Taiwan). X-10 now uses similar HiMark modules in their latest interface (CM15A). As I recall, HiMark has schematics and parts lists on their website.
    Jun 2006
    Bangalore, India
    Exclamation
    I finally found something on google that looks real easy to make.
    Can someone tell me if these circuits will work and what range they might have?
    http://www.cappels.org/dproj/LCRFLIN...tr/TRFxmtr.htm
    http://www.cappels.org/dproj/LCRFLIN...rF/TRFrcvr.htm
    Jun 2006
    Bangalore, India
    Arrow ???
    Has anyone got any other ideas???
    I just need a simple circuit that is capable of transmitting and recieving data.
    Range - 25 to 30 metres...
    Frequency - Anything . . .
    Dec 2005
    Shahidali, as you seem to want to build one yourself instead of buying ready made devices, the final result and performance will very much depend on your build quality and the quality of components you use and the antenna you employ at both the transmitter and receiver and also the frequency you end up operating on. Since the inductor will be constructed by you, I emphasise build quality. So, why not try building some of the many circuits you now have acquired (including some you've found yourself), then come back and tell us how you've done and how well they have performed. However, without some good test equipment, or alternatively at least a tuneable receiver in the frequency band of your transmitter, you will have a hard time achieving a measure of success whilst working in the dark, as you won't even know what transmit frequency your construction has ended up with.
    Wink
    A link to visit : http://www-k.ext.ti.com/srvs/cgi-bin/webcgi.exe?Company={5761bcd8-11f5-4e08-84e0-8167176a4ed9},kb=analog,case=obj(4270),new
  1. Interfacing 16F88 to RF module
    By scomi85 in forum General
    Last Post: - 19th February 2009, 12:52
  2. problem with sending data using RF module
    By rano_zen06 in forum mel PIC BASIC Pro
    Last Post: - 10th April 2008, 17:08
  3. Rf module
    By tangray in forum Adverts
    Last Post: - 7th August 2006, 07:14
  4. LINX RF module and PIC
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 18th January 2006, 22:44
  5. Interfacting RF Module
    By rastan in forum General
    Last Post: - 10th November 2004, 22:27
