Greetings from Newbie and a question
Results 1 to 10 of 10
    Feb 2005
    Essex, UK
    Default Pretty good
    Hi and welcome,
    that's pretty good code for a newbie but can I make a couple of suggestions to make life easier for yourself (not that I'm a pro by a long shot!):
    1). At the start of your program set up some variables so that you don't need to keep referring to which pin does what. By this I mean:
    'INPUTS
    Pressure_sw var portb.4 'Pressure_sw could be anything really so it could be smaller, say prsuresw instead or whatever you want that's easy to remember!
    Wlevel_sw var portb.5
    vaccum_sw var portb.6
    'etc,etc
    'OUTPUTS
    Airpump_relay var portc.0
    'etc,etc
    now in your program you can write:
    while Pressure_sw = 1 'Turn air pump on while pressure switch hi
    Airpump_relay = 1 'Keep it on until pressure is high enough
    wend
    Airpump_relay = 0 'Turn off air pump now that it is ready
    This is just a suggestion but it makes things a lot easier to read (especially when you come back to a program several months later!)
    2). Using the 'else' command I noticed you had problems so I thought I would re-write the code you posted with the proposed variables added and also showing how to use 'else'. You need to add a new line for the else and then add an endif after your instruction(s) also with their own lines:
    'Switches are a +5V HIGH on the input
    'Inputs (on Port B) are as follows:
    'Pin4 = Pressure switch
    'Pin5 = Water Level Float Switch
    'Pin6 = Vacuum switch
    'Pin7 = Temperature switch (preset value on the switch)
    ' Outputs (on Port C) are as follows:
    'Pin0 = Air Pump relay
    'Pin1 = "Water Low" LED or water pump relay
    'Pin2 = Injector Power relay (not currently used)
    'Pin3 = Injector "open" pulse
    TRISB = %11111111 ' Set all PORTB to inputs
    TRISC = %00000000 ' Set all PortC to outputs
    AllOff:
    PortC = 0 ' Turn off all outputs
    'Initial Air Pressure check to get pump going 1st if needed
    wend
    InitialOn: 'Wait for vacuum and temp to come up
    'and blink LED while waiting '
    'LED pulse
    Repeat
    WATER_LOW = 1 'Pulse the LED while in this loop
    PAUSEus 500
    WATER_LOW = 0
    PAUSEus 500
    Until Vac_sw = 1 and Temp_sw = 1 'Check Vacuum and Temp
    'Turn on injector power only if Vacuum
    'is detected and temp is High enough
    'Loop until ready
    pauseus 1000 'Pause to be sure engine running
    SensorCheck:
    'Check Air Pressure
    If Pressure_sw = 1 then
    Airpump_relay=1
    Airpump_relay=0
    'CheckWater Level
    If Wlevel_sw = 1 Then
    Water_low=1
    Water_low=0
    'Send pulse to injector while there is vacuum present.
    If Vac_sw = 1 Then PULSOUT Injector,50
    'Check Temperature and restart if too low (wait for temp to come up)
    If Temp_sw = 0 then AllOff:
    Goto SensorCheck: 'Loop the sensor check unless temp goes low
    I can't see where your problem is with the pump turning off but you could try commenting out this line:
    If portB.7 = 0 then AllOff
    or if you use the code I posted above, then it would be this line:
    I could be barking up the wrong tree but from a quick glance at your code I'm thinking the temperature switch might not be high?
    I hope this helps and your project sounds quite interesting
    Rob
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by Rob
    I can't remember how to add code the 'proper' way with its own scrolling box.
    Rob, use the term code between square brackets (remove the space between the [ and C of code)
    [ code ] [ /code ]
    Feb 2005
    Essex, UK
    Talking Forgetful
    Hi Malc-c,
    cheers for the reminder of "code", "close code"! If I had a brain that was big enough to support both my short term and long term memory I would probably be able to ......... no it's gone!
    Chris, I presume this project is for a turbo-charged car?! Let me guess, something old skool, RS Turbo? You don't have to say, just interested!
    Cheers
    Rob
    Jul 2006
    On demand Hydrogen generation from water as a catalyst/fuel in the combustion process. Water cools the flame instead of liquid gasoline, which is a terrible waste in all internal combustion engines today.
    (The things they DON'T tell you in car 101. :-) )
    I have the circuit working perfectly (with clearly labeled variables now.) I can't imagine how much time/pulled hair this saves even WITH the learning curve of using a PIC/Basic.
    I'll be using another, separate one dedicated to creating a custom square wave (PWM) needed for another part of the design.
    Chris
    Feb 2005
    Essex, UK
    Quote Originally Posted by ChrisHelvey
    That sounds VERY interesting - best of luck with it!
    - Glad variables are helping you!
    Chris, a little help with your project... you may already know this but anyways... the PIC16F877A also has Hardware PWM which is fantastic! You can set it and implement other code at the same time without worrying about its output frequency. You can easily change its frequency and stop the output alltogether. Check it out before using the PWM command.
    Good luck
    Rob
    Jul 2006
    I did NOT know that. That's fantastic. I don't use the PWM command to access it?
    I suppose I should look at the datasheet, but if you feel inclined to point me the right direction, it's appreciated.
    I was actually able to make a very nice square wave with an adjustable period/duty cycle by using pin on, pin off, and pauses. I won't need to make any duty cycle changes on-the-fly, but I may want to be able to turn it on and off at will.
    Thanks.
    Feb 2005
    Essex, UK
    This is a small portion of code that I wrote recently and may help you although it was written for a 16F628A:
    INTCON = %11000000     ' These 2 lines set the Timer 1 to be
    PIE1 = %00000001         ' utilised by enabling Global and Peripheral interrupts
    T2CON = %00000111           ' Timer 2 is needed by HPWM command
    CCP1CON = %00001100        ' This is needed also for HPWM command
        HPWM 1, 127, 0          ' Make sure the jets are off
    frequency = 2510                ' Set frequency at start -15Hz for Hotspring. - FREQUENCY WAS A VARIABLE I ASSIGNED!
    hpwm 1, 127, frequency        ' Output start frequency of 2510Hz
    The best thing to do is to read the datasheet for that particular PIC though as you quite rightly said. Also refer to the Pic Basic Pro manual - extremely helpful!!
