pbp245 compliation error
Results 1 to 10 of 10
    Newcastle, Australia
    Default the plot thickens....
    I did find in the picbasic forum, a thread that said to mod the
    compatibility properties to suit win98/Me, I did that and it fixed the compilation error.
    NOW the problem I have is, that the same program that will fit into
    the 877 when compiled by pbp232, wont fit if compiled by pbp245.
    I assume pbp245 has a few more includes that bloat the compiled file?
    any clues???
    cheers
    Woodzy
    I'll bet the core library has been updated between versions 2.32 and 2.45.
    This probably comes with a larger compiled program size depending on the
    library commands used in your code.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    You got it Bruce.
    Back to pbp232 while the 877's hold out.
    Cheers
    Woodzy
  1. Using input from Switch to control a loop
    Last Post: - 2nd February 2009, 05:02
  2. Loop with two motor and 2 sensors
  3. Optimizing DIV
    Last Post: - 22nd September 2008, 04:58
  4. 16F88 Compile error
    By Toley00 in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2005, 00:22
  5. Compiler/Assembler Error
    By LT_Pic in forum General
    Last Post: - 21st July 2005, 09:47
