You could make a voltage divider with another resistor, and then use the A/D converter to measure the voltage at the junction.
Charles Linquist
Thanks for suggesting, but I think this would require too current or would provide a very limited resolution due to the low value of the resistance to measure.
I think I should put some sort of amplifier in the middle, and this is a schema I'm looking for.
Leo
Why will it take too much current? if you put a 200 ohm resistor in series with the 330 ohm sensor, the total is 530 ohms, less than 10mA of current at 5V.
Unless you are battery-powered, that shouldn't be too much.
You should be able to get plenty of resolution with this arrangement.
Charles Linquist
