do I need an interrupt?
Results 1 to 5 of 5
    Default do I need an interrupt?
    Hello Everyone. I think I am in need of using an interrupt but can't get one to work. While constantly monitoring my inputs, I need another port to go high for approximately 1/2 second, go low for about 3 seconds and continue this until all of my inputs = 0. I can't use HIGH and PAUSE commands because it will miss the action on the inputs during the pause. I am also using both of the HPWM ports so I can't use them for this function either. If anyone can add some simple snippets in my code and briefly explain what is happening to accomplish this, I would greatly appreciate it.
    'COMPILED FOR 16F73
    adcon1 = 7 ' set inputs to digital
    @ DEVICE WDT_ON, BOD_ON, PWRT_ON, PROTECT_ON
    TRISA = %00100100 'RA2 & RA5 ARE INPUTS
    TRISB = %01111001 'RB0, 3, 4, 5, 6 ARE INPUTS
    TRISC = %00000001 'RC0 IS INPUT
    START:
    (MAKE THE MYSTERY PORT LOW)
    IF PORTB.0 = 0 THEN START
    WORK:
    (MAKE THE MYSTERY PORT HIGH FOR 500 AND LOW FOR 3000 MS WITHOUT MISSING ACTION ON INPUTS)
    DO SOMETHING HERE & THERE
    GOTO WORK
    Talking simple way
    Just drive pin 4 from the Mystery slave circuit ( 8 pins ooooooold timer , cmos version available, its generic number is 3 times 10 halves ... )
    Default Just a pointer
    OK, do a search for Timer interrupt first. in the interrupt routine you'll have to determine:
    1. i'm i on the HIGH pulse?... since how may time? enough? if so do the low pulse
    2. same as 1 for low pulse
    try it. If there's any other problem, i see some method.
    OR do a short pause loop, check the pin state in the loop.
    what I did was
    START:
    WORK:
    DO SOMETHING HERE & THERE 'this takes 250ms to complete
    LET X = X + 1
    IF X > 333 THEN GOSUB GOHIGH
    GOTO WORK
    GOHIGH:
    HIGH PORTC.3
    PAUSE 500
    LOW PORTC.3
    LET X = 0
    So, after about 3 seconds my port goes high for 500ms but I still have a 500ms + 250ms = 750ms gap where my inputs are ignored. A 555 one-shot would work fine but I want to avoid adding more circuitry if possible.
    Wink And with a little " RTFM " ??????
    As all your inputs are on PortB ... why not use the simple feature " interrupt on PortB change " ???
    you just have to check which input caused the interrupt and do what needed ...
    That would not disturb your PWM sections nor make great changes to your tempo's, even if a basic interrupt used.
    ( note it's an Excellent excercise for trying Darrel's Instant interrupts, too ... )
    just change PAUSE 500 to
    For i = 1 to 500
    PAUSE 1
    Next i
    ... as stated in the MANUAL, Basic interrupts section ....
  1. Won't go back to SLEEP after 1st Interrupt
    Last Post: - 29th June 2009, 10:00
  2. Can't ID interrupt source with this IntHandler??
  3. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  4. NEWBIE: Some basic questions using interrupts
    By JackPollack in forum mel PIC BASIC Pro
    Last Post: - 8th March 2006, 03:59
