Lcd
Results 1 to 11 of 11
Thread: Lcd
    Jun 2006
    Quote Originally Posted by mister_e
    also we don't know your PIC model, it can have analog stuff on any port. If they're not disabled .. it will never work.
    I use pic16f84a and pic16f628a
    on PIC16F628a you'll have to disable the analog comparator
    CMCON=7
    On both you should make sure the LVP fuse is disabled before programming.
    If your Crystal is >4MHZ be sure the OSC fuse is set to HS AND you have the according DEFIN at the top of your code.
    Be sure the MCLR pin is tie to somewhere
    etc
    etc
    The blink program idea is still remain so far
    Jun 2006
    i change PAUSE 100 to PAUSE 200 and it's ok.
    thank you.
  1. Is this code not initialising the LCD properly?
    By Platypus in forum mel PIC BASIC Pro
    Last Post: - 30th January 2010, 20:14
    Last Post: - 8th August 2009, 20:54
  3. LCD Problem
    By karenhornby in forum General
    Last Post: - 19th June 2008, 12:43
  5. LCD will not start
