serial Flowcontrol
Results 1 to 2 of 2
    Jul 2006
    Default serial Flowcontrol
    Hello
    How can I use flowcontrol in my code for serial communication?
    My board receive data from other device over serial port (inverted, also no MAX232 device), but I need to control the incomming data then I need time to execute few things after receive the data and in this time the sending device do not send any data, have anyone a idea how can I do that?
    Pedro
    Hangover, Germany
    You can use hardware- or software-flowcontrol.
    Each flowcontrol you use must be supported by the sending device !
    hardware-flowcontrol:
    the sender sets RTS in order to ask, if the MODEM (this old things) is ready to receive data. The modems answer by setting CTS. Your part is to lower and higher the CTS-signal.
    DTR is set by the Sender (Terminal) and DSR is set by the MODEM after power-on.
    software-flowcontrol:
    If you are full, to send a Ctrl-S (XOFF) and if you have completed your work, send Ctrl-Q (XON).
  1. Replies: 33
    Last Post: - 19th March 2010, 03:02
  2. Dynamic USB Serial Number (PIC18F4550)
    Last Post: - 16th July 2009, 17:03
  3. Parsing Serial data stream
    By boroko in forum Serial
    Last Post: - 26th October 2008, 11:12
  4. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 20:39
  5. interfacing to the pc serial port
    By kelangfei in forum General
    Last Post: - 7th October 2007, 22:35
