Move code in codespace
Results 1 to 4 of 4
    Wink The good question ...
    Where do PbP place its library files ???? .... so: RTFM, ...
    nothing strange here.
    sinoteq's Avatar
    sinoteq Guest
    Default Rtfm :)
    I have read the manual cover to cover many times and I can't find this information. Would you please be so kind and tell me where I can read about this. The manual is kind of weak in this subject.
    I don't get why PBP ignores the ORG statement in the BASIC file or is this a Bill Gates function? (forget what the user wants and do according to own ideas)
    The idea of using PBP is to minimize the ASM part of programing.
    Chapter 8.3 : Placement of in-line assembly ...
    ... reason to place libs here is probably the handling of page bits ... far before the 18xxx devices existed.
    sooooo ... , why do you want to give the low part adress ??? let PbP do it !!! and ONLY if necessary ( ! ) give the High part address.
    ( and think an asm statement resets to page 0 ... if you use something else than a 18xxx device !!! you must also care with PCLATH )
  1. PIC16F877A pwm use for IR transmission
    By mcbeasleyjr in forum General
    Last Post: - 11th July 2009, 19:51
  2. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 22:55
  3. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 22:31
  4. Loop with two motor and 2 sensors
  5. Making Program Code Space your playground...
