Isd4002
Results 1 to 5 of 5
Thread: Isd4002
    IceCube's Avatar
    IceCube Guest
    Default Isd4002
    Hi Forum,
    Does anyone have some BASIC code to get me started
    communicating with this chip?
    Thank you
    sonic's Avatar
    sonic Guest
    Question ISD problems
    Hi Ice!
    I suppose that we have the same problems with ISD chipcorders.
    Actually there is now two weeks of trying to do something with ISD33120 it`s pretty the same **** as ISD4002.
    Just to know you have a lot of FAQ on ISD web site..
    Good luck
    IceCube's Avatar
    IceCube Guest
    Default Re: ISD problems
    Hi Sonic,
    I finally got it to work!!
    Studying the TIMING CHART revealed my problem.
    Good luck to you.
    atomski's Avatar
    atomski Guest
    Could you share it with us, please? This section is called
    CODE EXAMPLES, after all
    YZ7REA Vladimir
    IceCube's Avatar
    IceCube Guest
    Sorry for the tardiness. (I have been away)
    The following routines work for me...
    The code is incomplete but should give some ideas.
    CmdPwrUp con $20
    CmdPlay con $F0
    CmdRec con $B0
    CmdStop con $30
    CmdStopPwrDn con $10
    MOSI var PortC.4 'Output
    MISO var PortC.5 'Input
    SCLK var PortC.6 'Output
    SS var PortC.7 'Output
    ISDInt var PortD.3 'Input
    RecordAudio: ' Record message
    LOW SS 'Enable isd4002
    SHIFTOUT MOSI,SCLK,0,CmdPwrUp\8]
    HIGH SS 'DisAble isd4002
    PAUSE 20
    debug "Recording... Adr=",hex4 ISDAdress,cr,lf 'Show ddr
    ISDAdress.13=1:ISDAdress.15=1 'Set PwrUp and RUN bits
    LOW SS 'Select isd4002
    SHIFTOUT MOSI,SCLK,0,[ISDAdress\16]
    HIGH SS 'De-Select isd4002
    debug "Recording till TIME out",cr,lf 'Instruct to REC
    pause time 'record TIME
    gosub StopOp 'Issue StopOperation cmd
    debug "StopOp Recording issued.",cr,lf 'Show progress
    StopPwrDn: ' Reset ISDInt and power down cmd
    LOW SS
    SHIFTOUT MOSI,SCLK,0,[CmdStopPwrDn\8]
    HIGH SS
    pause 20
    StopOp: ' Stop Operation
    LOW SS
    SHIFTOUT MOSI,SCLK,0,[CmdStop\8]
    HIGH SS
    pause 20
    PLAY: ' Play Audio
    LOW SS
    HIGH SS
    PAUSE 20
    HIGH SS
    PAUSE 20
    debug "Playing... Adr=",hex4 ISDAdress," " ISDAdress.15=1:ISDAdress.14=1:ISDAdress.13=1
    LOW SS
    SHIFTOUT MOSI,SCLK,0,[ISDAdress\16] 'SetPlay cmd
    HIGH SS
    pause 20
    I am new to pasting code and I hope my EDITS did not
    destroy any of the code.
    Good luck
  1. Pic+isd4002
    By eyalf in forum mel PIC BASIC Pro
    Last Post: - 14th November 2012, 06:32
  2. isd4002 problems help required please
    By Agent36 in forum mel PIC BASIC Pro
    Last Post: - 29th March 2012, 07:57
  3. ISD4002 Address Question
    By Atom058 in forum mel PIC BASIC Pro
    Last Post: - 24th August 2009, 00:42
  4. Shot meself in the foot again...
    By muddy0409 in forum mel PIC BASIC Pro
    Last Post: - 6th July 2007, 20:30
  5. Ask For Help
    By Bakari in forum mel PIC BASIC
    Last Post: - 22nd September 2006, 17:42
