Button help
Results 1 to 22 of 22
Thread: Button help
    homebrewer's Avatar
    homebrewer Guest
    Quote Originally Posted by mister_e
    ADCON1=7 have nothing usefull to do with the 16F627 but compilation error. There's no ADCs in the PIC16F627, just analog comparator.
    CMCON=7
    I'm a beginner too. I had also problems to query PORTA. The tip with CMON=7 was the solution. Steve, thank you very much!
    _______________
    Johann
    Default Meeee Tooo
    Attention fellow newbies:
    Here's what I learned the hard way, twice!
    When your button code calls a LABEL,
    put that labeled code in the very next line after your button code,
    or you get nasty error codes assuring you that it is not really a label.
    I ran into this in a program with several sub routines and several buttons
    and the only way it would compile was if I put the subs directly after the button.
    SWITZERLAND (french speaking)
    I can't make it work with the BUTTON command.
    So I tried the other way and use the simple IF..THEN command.
    But again, I have the same unexpected result. The Led starts to blink when I press the button. As I release the button, it never "toggles" as I want it to do.
    Since this program behavior is the same in both cases (BUTTON and IF..THEN commands), I assume something is wrong with some register settings.
    I was thinking about a bouncing problem, but I'm not sure about that.
    Here is my code; where do I miss something?
    'PIC 16F88
    'Button is on PORTB.3 (Pin 9) Pressed = 0V
    'Led is on PORTB.4 (Pin 10)
    OSCCON = %01100000 'Internal RC set to 4MHZ
    TRISB = %00001000 'RB3 is an Input, all others are Outputs
    ' IF..THEN
    MAIN:
    IF PORTB.3 = 0 then SWITCH_LED
    SWITCH_LED:
    pause 100 'Debounce
    toggle PORTB.4
    ' BUTTON
    'BVar var byte
    'BVar = 0
    'MAIN:
    ' BUTTON 9, 0, 255, 255, BVar, 0, SWITCH_LED
    ' goto main
    'SWITCH_LED:
    ' pause 100 'Debounce
    ' toggle PORTB.4
    ' goto main
    Roger
    MAIN:
    SWITCH_LED:
    pause 100 'Debounce
    toggle PORTB.4
    So what happens above when you keep your finger pressed on the button for longer than 100mS? Your LED will keep toggling every 100mS...
    Try this...
    MAIN:
    SWITCH_LED:
    pause 100 'Debounce
    toggle PORTB.4
    While PortB.3=0:Wend ' Wait here for Button to be released
    homebrewer's Avatar
    homebrewer Guest
    ' Try CMCON=7 as mister_e has stated in reply#3
    ' now you can query input pins
    ' from this point it's up to you, how your led should work
    CMCON=7
    MAIN:
    SWITCH_LED:
    pause 100 'Debounce
    toggle PORTB.4
    ' Regards
    ' Johann
    CMCON has no effect on PortB on this PIC.
    homebrewer's Avatar
    homebrewer Guest
    Hello Melanie,
    you are very right. I have looked into the datasheet after my reply.
    I was too overhasty - sorry!
  1. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 08:10
  2. 3 HPWM channels
    Last Post: - 4th April 2006, 02:43
  3. Code check -- button not working
    Last Post: - 2nd March 2006, 22:43
  4. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 10:06
  5. Button subfunction 16F628
    By Jųan in forum mel PIC BASIC Pro
    Last Post: - 19th August 2005, 16:44
