ADCON1=7 have nothing usefull to do with the 16F627 but compilation error. There's no ADCs in the PIC16F627, just analog comparator.
CMCON=7
CMCON=7
I'm a beginner too. I had also problems to query PORTA. The tip with CMON=7 was the solution. Steve, thank you very much!Originally Posted by mister_e
_______________
Johann
Attention fellow newbies:
Here's what I learned the hard way, twice!
When your button code calls a LABEL,
put that labeled code in the very next line after your button code,
or you get nasty error codes assuring you that it is not really a label.
I ran into this in a program with several sub routines and several buttons
and the only way it would compile was if I put the subs directly after the button.
I can't make it work with the BUTTON command.
So I tried the other way and use the simple IF..THEN command.
But again, I have the same unexpected result. The Led starts to blink when I press the button. As I release the button, it never "toggles" as I want it to do.
Since this program behavior is the same in both cases (BUTTON and IF..THEN commands), I assume something is wrong with some register settings.
I was thinking about a bouncing problem, but I'm not sure about that.
Here is my code; where do I miss something?
'PIC 16F88
'Button is on PORTB.3 (Pin 9) Pressed = 0V
'Led is on PORTB.4 (Pin 10)
OSCCON = %01100000 'Internal RC set to 4MHZ
TRISB = %00001000 'RB3 is an Input, all others are Outputs
' IF..THEN
MAIN:
IF PORTB.3 = 0 then SWITCH_LED
SWITCH_LED:
pause 100 'Debounce
toggle PORTB.4
' BUTTON
'BVar var byte
'BVar = 0
'MAIN:
' BUTTON 9, 0, 255, 255, BVar, 0, SWITCH_LED
' goto main
'SWITCH_LED:
' pause 100 'Debounce
' toggle PORTB.4
' goto main
Roger
MAIN:
SWITCH_LED:
pause 100 'Debounce
toggle PORTB.4
So what happens above when you keep your finger pressed on the button for longer than 100mS? Your LED will keep toggling every 100mS...
Try this...
MAIN:
SWITCH_LED:
pause 100 'Debounce
toggle PORTB.4
While PortB.3=0:Wend ' Wait here for Button to be released
' Try CMCON=7 as mister_e has stated in reply#3
' now you can query input pins
' from this point it's up to you, how your led should work
CMCON=7
MAIN:
SWITCH_LED:
pause 100 'Debounce
toggle PORTB.4
' Regards
' Johann
