Button help
Results 1 to 22 of 22
Thread: Button help
    darklight's Avatar
    darklight Guest
    Default Button help
    Hey people.
    I'm new to microcontrolers and picbasic.
    I was just wondering if anyone could help me with switchs.
    I can already output leds from portB.
    PIC = 16F627
    I'm using a programmer / test board (VELLEMAN VM111) to test buttons and leds.
    The leds = 6 on portB
    Buttons = 4 on portA
    Thanks for any help.
    blainecf's Avatar
    blainecf Guest
    Default Checklist for buttons
    Make sure:
    1. ADCON1 = 7 so that your PORTA pins are digital
    2. Set the appropriate TRISA.x = %1 for Digital Input
    3. Wire a pull-up resistor (10K from V+ to each pin that will sense the switch)
    4. Wire each switch, one side ground, the other to the pin from step #3
    5. Set up a loop for polling the ports; High (%1) will be normal, and Low (%0) will show when the switch is held closed.
    If you're not used to digital signals, it seems weird to ground out a resistor thats hooked to V+, but just accept it.
    Default MIIIP something's wrong :)
    ADCON1=7 have nothing usefull to do with the 16F627 but compilation error. There's no ADCs in the PIC16F627, just analog comparator.
    CMCON=7
    homebrewer's Avatar
    homebrewer Guest
    Quote Originally Posted by mister_e
    CMCON=7
    I'm a beginner too. I had also problems to query PORTA. The tip with CMON=7 was the solution. Steve, thank you very much!
    _______________
    Johann
    Default Meeee Tooo
    Attention fellow newbies:
    Here's what I learned the hard way, twice!
    When your button code calls a LABEL,
    put that labeled code in the very next line after your button code,
    or you get nasty error codes assuring you that it is not really a label.
    I ran into this in a program with several sub routines and several buttons
    and the only way it would compile was if I put the subs directly after the button.
    SWITZERLAND (french speaking)
    I can't make it work with the BUTTON command.
    So I tried the other way and use the simple IF..THEN command.
    But again, I have the same unexpected result. The Led starts to blink when I press the button. As I release the button, it never "toggles" as I want it to do.
    Since this program behavior is the same in both cases (BUTTON and IF..THEN commands), I assume something is wrong with some register settings.
    I was thinking about a bouncing problem, but I'm not sure about that.
    Here is my code; where do I miss something?
    'PIC 16F88
    'Button is on PORTB.3 (Pin 9) Pressed = 0V
    'Led is on PORTB.4 (Pin 10)
    OSCCON = %01100000 'Internal RC set to 4MHZ
    TRISB = %00001000 'RB3 is an Input, all others are Outputs
    ' IF..THEN
    MAIN:
    IF PORTB.3 = 0 then SWITCH_LED
    SWITCH_LED:
    pause 100 'Debounce
    toggle PORTB.4
    ' BUTTON
    'BVar var byte
    'BVar = 0
    'MAIN:
    ' BUTTON 9, 0, 255, 255, BVar, 0, SWITCH_LED
    ' goto main
    'SWITCH_LED:
    ' pause 100 'Debounce
    ' toggle PORTB.4
    ' goto main
    Roger
    MAIN:
    SWITCH_LED:
    pause 100 'Debounce
    toggle PORTB.4
    So what happens above when you keep your finger pressed on the button for longer than 100mS? Your LED will keep toggling every 100mS...
    Try this...
    MAIN:
    SWITCH_LED:
    pause 100 'Debounce
    toggle PORTB.4
    While PortB.3=0:Wend ' Wait here for Button to be released
    homebrewer's Avatar
    homebrewer Guest
    ' Try CMCON=7 as mister_e has stated in reply#3
    ' now you can query input pins
    ' from this point it's up to you, how your led should work
    CMCON=7
    MAIN:
    SWITCH_LED:
    pause 100 'Debounce
    toggle PORTB.4
    ' Regards
    ' Johann
    CMCON has no effect on PortB on this PIC.
    homebrewer's Avatar
    homebrewer Guest
    Hello Melanie,
    you are very right. I have looked into the datasheet after my reply.
    I was too overhasty - sorry!
    Appologies are unnescessary.
    flotulopex reported that his LED blinks when he pushes the button, that's because there's only a 100mS Pause in the loop and you toggle the LED-ON, and with your finger still on the button, 100mS later you toggle it OFF, and with your finger still on the button, the LED toggles again 100mS later... etc etc until the end of time.
    You need to ensure that once the LED toggles, it doesn't do so again until the Button is pressed anew. There are MANY, MANY ways of doing this. The example I posted simply waits for the user to remove his finger from the button before proceeding further.
    Thank you Melanie,
    Actually, it still doesn't work.
    Each time I press the button, the Led lights up and as soon as I release the button, the Led switches off. At least, it doesn't blink anymore while the button is pressed.
    It just doesn't want to toggle!
    To make sure my button is correctly connected, is this schematic okay?
    > Vdd-R10k-PORTB.3 and the button (normally open) is derived from PORTB.3 to Vss.
    Since I can't make it work with this simple program, my last guess would be that my PIC is defect. I tried with other ports but there is no change. I shall receive another PIC tomorrow.
    By the way, is there any utility tool to check the PIC's health?
    Roger
    MyButton var PortB.3
    LED var PortB.4
    TRISB = %00001000
    Loop:
    If MyButton=0 then
    Toggle LED
    While MyButton=0:Pause 100:Wend
    Goto Loop
    Try the above and report back what the result is...
    Mar 2006
    INDIA
    'PIC 16F84A
    TRISA = %000001
    TRISB = %11111100
    I VAR BYTE
    PAUSE 200
    MAIN:
    IF PORTA.0 = 1 then SWITCH_LED
    SWITCH_LED: IF PORTA.0 = 0 THEN SWITCH_LED_INSTANT
    FOR I = 0 TO 10
    IF I < 10 AND PORTA.0 = 0 THEN SWITCH_LED_INSTANT
    PAUSE 100
    NEXT I
    IF PORTA.0 = 1 THEN SWITCH_LED_DELAY
    SWITCH_LED_DELAY: TOGGLE PORTB.0
    PAUSE 10
    AVOID_LED_BLINK: IF PORTA.0 = 1 THEN AVOID_LED_BLINK
    PAUSE 10
    GOTO MAIN
    SWITCH_LED_INSTANT: TOGGLE PORTB.1
    PAUSE 10
    GOTO MAIN
    JARI NETWORKS's Avatar
    JARI NETWORKS Guest
    I'm also a new one with de pic chips, can I use this also for a 16F628A chip??
    grz Jan
    Default Melanie, I tested your piece of code
    Hello Melanie,
    Your piece of code didn't work until I... grounded PORTB.2.
    So I tried my code and it worked well too.
    I didn't expect this component to be so sensible to the electric field around the pins.
    I won't forget this lesson, for sure ;-)
    Roger
    JARI NETWORKS Guest
    so many viewers, and nobody can give me an answer??
    malc-c's Avatar
    malc-c Guest
    Quote Originally Posted by JARI NETWORKS
    grz Jan
    If you are meaning "can you use the button command with the 16f628a chip, then the answer is yes
    JARI NETWORKS Guest
    ok thanks,that was all I want to know at this moment
    Jan 2008
    lincoln uk
    Default polling portb
    On the side, could you tell me the correct syntax to poll portb in a for..next loop?
    viz
    FOR i = 0 to 7
    IF portb.[i]=0 THEN GOSUB alarm
    NEXT i
    This doesn't work and I can't find the answer in the book
    Quote Originally Posted by blainecf View Post
    Make sure:
    skimask's Avatar
    skimask Guest
    Quote Originally Posted by med2007 View Post
    viz
    FOR i = 0 to 7
    NEXT i
    http://www.picbasic.co.uk/forum/showthread.php?t=544
    Jan 2008
    lincoln uk
    Thanks for the link...so my syntax should be?
    FOR i = 0 to 7
    IF portb.0(i) = 0 THEN GOSUB alarm
    NEXT i
    I'll give it a whirl.
    Rgds
    MED2007
  1. Sony SIRC IR Issue
    By Ryan7777 in forum mel PIC BASIC Pro
    Last Post: - 8th August 2015, 09:10
  2. 3 HPWM channels
    By docwisdom in forum mel PIC BASIC Pro
    Last Post: - 4th April 2006, 03:43
  3. Code check -- button not working
    Last Post: - 2nd March 2006, 23:43
  4. Button Push within 3 second Window
    Last Post: - 22nd December 2005, 11:06
  5. Button subfunction 16F628
    By Jųan in forum mel PIC BASIC Pro
    Last Post: - 19th August 2005, 17:44
