PIC Hangs when using Serin TimeOut
Results 1 to 3 of 3
    Oct 2003
    Australia
    Unhappy PIC Hangs when using Serin TimeOut
    I've seen this problem a few times now and its strange.
    It's the same with both Serin or HSERIN. eg
      EXAMPLE:
      HSERIN 1500, FAIL,[WAIT ("HERE IT IS")]
      HSEROUT ["I GOT IT"]
      GOTO EXAMPLE
      FAIL:
      HSEROUT["BAD WIRING"]
      GOTO SOMETHING ELSE
    This example works fine if all connections are correct, but if I cross over GND and RX wire (eg deliberate wire mistake) then it just causes the PIC to Hang up waiting and not preceed after 1.5 secs to FAIL.
    Why is this so? ( I have WDT set to ON too.)
    I need to allow for this wire mistaking and get the program recognize this and do something else (eg check another serial input pin for instance)
    Cheers
    Squib
    Oct 2003
    Australia
    Thanks Mistere.
  1. PIC HANGS with SERIN and Timeout?
    Last Post: - 18th January 2008, 17:33
  2. SERIN AND SEROUT PROBELM USING 16f690 PIC
    By Charles in forum mel PIC BASIC Pro
    Last Post: - 18th January 2007, 03:59
  3. 16F628A Serin timeout and Timer1
    Last Post: - 26th March 2006, 23:20
  4. SERIN SERIN2 Timeout
    By markedwards in forum mel PIC BASIC Pro
    Last Post: - 23rd June 2005, 18:59
  5. SERIN & Timeout
    By BigWumpus in forum mel PIC BASIC Pro
    Last Post: - 30th October 2004, 07:33
