DS 1620 Code example?
Results 1 to 8 of 8
    May 2006
    MI
    Default DS 1620 Code example?
    Hello
    After doing a quick search here and on Google, I was able to find 1 minor
    example code for PBP. In a project using another company's complier
    my code has run out of memory. This forces my project into a situation
    where a newer 18 pin PIC like the 16F88 is required. And that is the main
    problem. As this pic is not supported by them.
    Will someone help point me into the right direction as where to find code
    for the DS 1620 for PBP.
    Thanks gang
    Gordon
    Jan 2006
    Istanbul
    Hi Gordon,
    Thanks to Bruce.
    Here you can find an example in which you can see the code for DS1620.
    http://www.rentron.com/PicBasic/SERLED.htm
    May 2006
    MI
    AHH-HA
    Yes thats what I had in mind.
    Thank you Sazyer.
    Mar 2006
    INDIA
    ' PicBasic Pro program to read DS1620 3-wire temperature sensor
    ' and display temperature on LCD
    ' Define LOADER_USED to allow use of the boot loader.
    ' This will not affect normal program operation.
    Define LOADER_USED 1
    Include "MODEDEFS.BAS"
    ' Define LCD pins
    Define LCD_DREG PORTD
    Define LCD_DBIT 4
    Define LCD_RSREG PORTE
    Define LCD_RSBIT 0
    Define LCD_EREG PORTE
    Define LCD_EBIT 1
    ' Alias pins
    RST var PORTC.0 ' Reset pin
    DQ var PORTC.1 ' Data pin
    CLK var PORTC.3 ' Clock pin
    ' Allocate variables
    temp var word ' Storage for temperature
    Low RST ' Reset the device
    ADCON1 = 7 ' Set PORTA and PORTE to digital
    Low PORTE.2 ' LCD R/W line low (W)
    Pause 100 ' Wait for LCD to start
    Lcdout $fe, 1, "Temp in degrees C" ' Display sign-on message
    ' Mainloop to read the temperature and display on LCD
    mainloop:
    RST = 1 ' Enable device
    Shiftout DQ, CLK, LSBFIRST, [$ee] ' Start conversion
    RST = 0
    Pause 1000 ' Wait 1 second for conversion to complete
    RST = 1
    Shiftout DQ, CLK, LSBFIRST, [$aa] ' Send read command
    Shiftin DQ, CLK, LSBPRE, [temp\9] ' Read 9 bit temperature
    RST = 0
    ' Display the decimal temperature
    Lcdout $fe, 1, dec (temp >> 1), ".", dec (temp.0 * 5), " degrees C"
    Goto mainloop ' Do it forever
    or read http://www.melabs.com/resources/samp...pbp/temp3x.bas
    May 2006
    MI
    Thanks precision
    This code looks very clean and striaght forward.
    This should be easy to apply to my project.
    Gordon
    Mentor, Ohio
    Smile
    Hi Gordon,
    I see from your other post regarding ISP Pro that you purchased PICBasic. Did you get the PICBasic Compiler or did you get the PIC Basic Pro version. There are distinct differences between the 2 programs.
    Just trying to save you the time of using the above program with PIC Basic.
    BobK
    Wink Simple ... make it simple
    Why not try here:
    http://www.rentron.com/PicBasic/one-wire3.htm
    simply ...
    May 2006
    MI
    Thanks for the link ace. I purchased the pro after reading Chuck Hellebuyck's
    book "Programming Pic Microcontrollers with PicBasic". Just seemed like PBP
    was the way to go when using LCDs and a few other features.
    Gordon
  1. Reading in Manchester code
    By brid0030 in forum Code Examples
    Last Post: - 10th March 2009, 21:55
  2. How much code space do PBP statements use.
    Last Post: - 13th February 2009, 21:31
  5. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 17:23
