PIC16F818 ADC Problem
Results 1 to 5 of 5
    Hi Bob. This is how I use the 818 & 819. I prefer the easier 255 step ADC but used the 1024 in the past with no problem.
    OSCCON = $60 'set int osc to 4mhz
    'USE OSCCON = $70 for 8mhz
    adcon1 = 7 ' set inputs to digital. adcin command will convert to analog
    MYVAR VAR BYTE
    'uncomment & use the following 4 lines for 1024 step conversion INSTEAD of 'var byte
    'MYVAR VAR WORD
    'DEFINE ADC_BITS 10 ' Set number of bits in result
    'DEFINE ADC_SAMPLEUS 50 ' Set sampling time in uS
    'ADCON1.7 = 1 'RIGHT JUSTIFY RESULT
    @ DEVICE MCLR_ON, INTRC_OSC, WDT_ON, LVP_OFF, BOD_OFF, PWRT_ON, PROTECT_ON
    Feb 2005
    Holmfirth England
    Thanks, but I just tried that & still get the same results, a maximum of 3 as the a/d result. I have tried chips from different batches, various settings for the adc clock, I am using a 8MHz resonator for the clock. I have measured the voltage on the pin (pin 17), and it varies from 0 to 5V. I have used the 818 in the past with no problems. That time I had a 20MHz osc, so I used clock / 64, i.e. ADCON0 = 129, ADCON1 = 206 and it worked fine. I just cant see why it wont work.
    Oh well I'll keep trying....
    Try not using your ADCON statements. I've never used them & always worked for me. Also try the internal oscillator @ 4MHZ. Your program looks like it should work.
    Feb 2005
    Holmfirth England
    Thanks for your help.
    I have got rid of the ADCON commands, and fitted an lcd display, it now works, kind of. It will work as an 8 bit a/d. Very strange, as I said I have used the 10 bit a/d of an 818 before. 8 bits will do though, in this case.
    Bob...
  1. PIC18F2423, ADC problem
    By mistergh in forum mel PIC BASIC Pro
    Last Post: - 17th March 2009, 02:31
  2. Mutliple ADC problem with PIC16F877
    By andyto in forum mel PIC BASIC Pro
    Last Post: - 3rd October 2007, 18:47
  3. Problem getting PIC16f818
    By jjohannson in forum mel PIC BASIC Pro
    Last Post: - 8th March 2007, 18:03
  4. ADC problem with PIC16F917
    By eetech in forum mel PIC BASIC Pro
    Last Post: - 7th March 2007, 22:22
  5. 16F876 ADC problem
    By Douwe in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 20:38
