Delta-Sigma Converter
Results 1 to 10 of 10
    Feb 2005
    Portugal
    Default Delta-Sigma Converter
    Hi.
    I'm trying to read directly from a PIR sensor (3.3mVpp) using a PIC.
    I read in Microchip AN700 it's possible using Delta-Sigma Converter to increase resolution (to 20 bits !!!!) then sense small signals, like this one.
    How i can do that? I'm a little confused...
    Hangover, Germany
    Smile
    Äh,
    flux-compensator ?
    Feb 2005
    Portugal
    Sorry but i don't understand... ???
    Dec 2003
    plano, texas usa
    I have used a pic and a cs5524 (24 bit a/d ) this uses shift in / out commands. I had 19 bits efffectivly. Remember your input circuits need to be layed out carefully to take advantage of available dynamic range.
    regards
    leonel, have a look at the MCP355x series of Delta-Sigma Converters. I have done some work with the MCP3553 and am planning on incorporating into a new design. They are fully differential and the MCP3553 has a 16Ms. update rate. The series is made by Microchip.
    Feb 2005
    Portugal
    Using MCP3553 probably will work, but my circuit is to be supplied with 4 batteries of 1.5V, +-700mAh. MCP3553 has 170uA of current supply it's a little too much.
    I would like to have a consume of about +-20uA.
    leonel, In shutdown mode it only draws 1 uA...... In sleep mode it only draws 10uA......
    Feb 2005
    Portugal
    You're right Dave. I took a better look after, and i read what you say.
    Probably i will follow you're advise, but first i will see if there are another cheaper solution... (but i don't think so...)
    Thank you.
    Sep 2005
    Campbell, CA
    Have you thought of amplifying the sensor's output with an op-amp before you feed it into the A/D?
    A gain of 1000 isn't hard to do with one or two stages. Your 3.3mV p-p would then be 3.3V p-p.
    Charles Linquist
    Feb 2005
    Portugal
    yes, i already thought... It was my first solution.
    But micro-power opamps are expensive, and consumes a little more than MCP3553.
  1. serial to usb converter
    By nicjo in forum Serial
    Last Post: - 18th September 2008, 00:52
  2. Delta Sigma ADC is inverting
    By selbstdual in forum mel PIC BASIC Pro
    Last Post: - 30th January 2007, 16:35
  3. 16F88 - AD converter module always "ON"
    Last Post: - 18th September 2006, 13:11
  4. Step up converter
    By Ron Marcus in forum Off Topic
    Last Post: - 27th July 2006, 21:44
  5. RS-232 async to sync converter
    By jmartin in forum mel PIC BASIC Pro
    Last Post: - 12th October 2005, 00:04
