water flow meter..
Results 1 to 10 of 10
    Hangover, Germany
    Don't write to often to the EEPROM on the same position !
    Think about a ring-buffer !
    Maybe:
    Get the olf value.
    Count...
    Write the new value to the next position and a checksum out of the new and the old value (asume a fixed value for non-existing old values!). If you reach the end of EEPROM, begin on the first position.
    After Power-On
    0: store 0 as backup-value.
    1: read a value, check checksum.
    2: if checksum is ok, store the value as Backup, goto 1
    3: if checksum is bad, use the backup-value and exit
    Just read to manual !
    Maybe you can build hardware to buffer the pic fpr around 10ms to write the eeprom and then turn off. Use the Brown-Out-Reset !!!!
    Mentor, Ohio
    Hi Ecca,
    Can you provide us with some information on the flow meter, such as the manufacturer and part number, perhaps a web site to look at this sensor closer?
    BobK
    For saving to the EEPROM, choose a PIC with a LVD (Low Voltage Detect) interrupt.
    When the power is turned off, the interrupt gets triggered, quickly save to EEPROM while the chip is still running on the capacitor charge.
    The rest of the time, the value is available in RAM. No need to save it on every loop.
    Or a comparator interrupt OR modify the power supply. You place a diode between the bridge and the capacitor, then send the bridge side on a interruptable pin.
    Just another idea
    How many different ways exist to skin a cat?
    Sep 2005
    Campbell, CA
    The 18F8722 datasheet claims the EEPROM is typically good for a million write cycles. I would probably trust it for 500K cycles.
    Charles Linquist
    ecca's Avatar
    ecca Guest
    Right then, having returned from holidays..... I continue.
    I only require a 3 digit LCD with about 12mm digits.
    What's around at the moment ?
    Thanks for help all,
    Ecca
  1. Hall Effect flow meter with 16F876
    By revelator in forum mel PIC BASIC Pro
    Last Post: - 10th March 2010, 21:42
  2. Can't ID interrupt source with this IntHandler??
  3. NMEA 2000 Flow Meter
    By Joe Rocci in forum mel PIC BASIC Pro
    Last Post: - 6th August 2008, 01:35
  4. Electric water valve
    By Christopher4187 in forum Off Topic
    Last Post: - 6th April 2008, 22:41
  5. hot water flow sensor
    By jessey in forum Off Topic
    Last Post: - 24th January 2007, 05:05
