PIC 12F675 RF use
Results 1 to 13 of 13
    May 2005
    Minnesota
    Default PIC 12F675 RF use
    Anyone use the RF transmitter in this Microchip device and the receiver in Microchips rfRXD0420?
    I have had some success with transmitter/receiver modules, but these look very interesting. I'm most curious about antenna design for these devices.
    If anyone has used these I would like to hear about pitfalls and problems encountered. Circuit design suggestions . . .
    Many thanks.
    Brad
    Dec 2005
    I haven't used them but did evaluate them for an application that uses a PIC12F675 and a standalone SAW controlled transmitter (from Wen Shing). It cost less and was far simpler to stay with the separate components.
    Quote Originally Posted by cooksydesign
    Brad
    Here : http://www.microchip.com/stellent/id...AN831&x=9&y=10
    just browse ...
    May 2005
    Minnesota
    Default Antenna design
    Thanks to both.
    Brad
    Sep 2003
    Vermont
    Do you have any design criteria?
    Sep 2003
    INDIA
    I have some samples with me and would really like share your experience.
    So keep us posted with your design feedback , BRAD.
    regards
    May 2005
    Minnesota
    Default design criteria
    Only parameters I have at the moment are size, distance, and power requirements.
    The size of the circuit board has to be about 1 inch tall and 1.5 wide. Powered by a 9 volt transistor battery through a 3.3 voltage regulator. Distance for transmitting data is less than 100 feet, probably closer to 50 feet.
    I think thats all I have right now. I haven't started yet, just gathering info. Best place to start, other than Microchips' site, is here.
    Thanks for all the responses.
    B
  1. mrf24j40 RF transciever with pic
    Last Post: - 17th September 2008, 15:11
  2. RF transmiter reciever using PIC
    By drama in forum mel PIC BASIC
    Last Post: - 4th October 2007, 16:26
  3. Generating RF from a PIC
    By Rob Martin in forum mel PIC BASIC Pro
    Last Post: - 26th January 2006, 20:26
  4. LINX RF module and PIC (#2)
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 22nd January 2006, 17:56
