How often do you service USB?
Results 1 to 4 of 4
    Default How often do you service USB?
    Ok,
    I've finally figured out how to have basic communication between a PIC 18F4550 and the PC using USB and PIC Basic Pro. As the thread says, how do you go about figuring when you are due to issue a USBSERVICE command?
    Can I use the generated Assembler file and count how many commands were issued since the previous USBSERVICE?
    I was thinking of sprinkling LABELS throughout the sections of code that I want to 'optimize'. That way it would help me identify what assembler commands relate with what basic commands.
    Or are things not that easy?
    place the USBSERVICE in a Timer interrupt routine. Interrupt at every XYZ<10-20Msec will handle everything for you. As now it work like a charm for me. Look the instant interrupts of Darrel... couldn't be much simple.
    http://www.picbasic.co.uk/forum/showthread.php?t=3251
    Merci mon pote!
    The wife bellows, I'll check it out after dinner.
    Pas de probleme pepere
  1. USB CDC Communications for Dummies!
    By Squibcakes in forum USB
    Last Post: - 15th January 2014, 13:43
  2. Simple USB Comms Problem
    Last Post: - 6th January 2010, 20:17
  3. One USB keyboard to Two USB Ports
    By picnaut in forum mel PIC BASIC Pro
    Last Post: - 11th June 2009, 00:04
  4. USB to COM converter
    By iugmoh in forum USB
    Last Post: - 20th April 2008, 14:19
  5. USB PIC without USB Connection
    Last Post: - 26th December 2005, 17:39
