Ability to export meLabs Programmer Configuration settings
Results 1 to 8 of 8
    Any API are not so hard to implement in a program depending how great they are documented, in the case of Mecanique, it's always great documented. So for most of people here who already program in VB, VC++, Delphi or else, it shouldn't be a problem. Do a ggogle search and you'll find tons of example on 'how to use/implement API'
    But there's probably some deal between Crownhill and Mecanique about that... or probably not. Since it's probably the first time we talk of that on-line, there's probably some evaluation time prior to add this feature.
    Darrel, as you said, both IDE seems to be quite similar, so it shouldn't be too much of a problem.
    Finger crossed!
    In meantime, we have the Mecanique ICD for free.. wich it's not the case in PROTON. Their ICD is made by a third party and you should pay for.
    Many person here think that the ICD and IDE is made by Melabs... NO, No, NO, from Mr David Barker.
    David, please think about it. Need testers? drop me off list.
    After a quick look at this thread and .zip
    Plugin Development Api
    http://www.picbasic.org/forum/showthread.php?t=3201
    I see that it does work with Delphi, so I would definately be able to use it. So would a lot of others, with just about any other language.
    And looking at the Interface Reference, it has everything needed to do some really cool stuff.
    If there aren't any exclusivity clauses involved, I'd Love to see it in MCSP.
    an API is roughly an INCLUDE file so you'll be in a known environement
    I'm with you!
    Anybody else?
  1. Presetting Configuration Fuses (PIC Defines) into your Program
    Last Post: - 15th December 2013, 10:54
  2. Melabs U2 Programmer Command Line Options
    By Robert Wells in forum General
    Last Post: - 3rd July 2009, 03:11
  3. PIC 16F684 Configuration Settings
    By Nicholas in forum mel PIC BASIC Pro
    Last Post: - 11th April 2007, 16:18
  4. melabs usb programmer problem
    By bigbear in forum General
    Last Post: - 28th December 2006, 13:50
  5. Melabs USB Programmer
    By tmurph in forum General
    Last Post: - 25th December 2005, 04:25
