Code Issue? - Pin Labels
Results 1 to 5 of 5
Threaded View
  1. #4
    yeah but.. Both code use the High LOW statement... one use the PIN alias, not the other.
    I agree with the possibility of the analog stuff on every port, but.. it doesn't explain why the PIN alias don't work but the direct HIGH PORTB.x work ... at least it doesn't make sense to me...
    OK at the begining is the TRIS is not set, the following lines..
    LedA = 0
    LedB = 0
    LedC = 0
    LedD = 0
    won't do anything for sure unless LOW LEDx is used.
    Also we don't know if external pull-up resistor are used.. so that may cause some oddity, and so on
  1. Advice-scrutiny for my serial controller
    Last Post: - 13th December 2008, 18:11
  2. Making Program Code Space your playground...
  3. Code Issue - select case or 'if' issue - not sure why
    Last Post: - 7th October 2007, 09:52
  4. Re-Writing IF-THEN-AND-ENDIF code?
    Last Post: - 18th August 2006, 18:23
  5. Keypad unlock (as in garage door possibly)
    By Fred in forum Code Examples
    Last Post: - 2nd April 2006, 05:26
