Ask For Help
Results 1 to 19 of 19
Thread: Ask For Help
    To make things simple, you'll need to use SHIFTIN/SHIFTOUT in PBP. so it doesn't really matter the PIC I/O you use.
    A while back i used a PIC16F628, Bellow is the hardware assignement i used.
        ' I/O Definition
        TRISA = %00110000    ' PORTA Output on :
                             '         PORTA<3:0> : LCD data
                             '         PORTA<7:6> : LCD RS & E bit
                             ' PORTA Input on :
                             '         PORTA.4 : "ALT PLAY" Button
                             '         PORTA.5 : "PLAY" button
        TRISB = %11110001    ' PORTB Output on :
                             '         PORTB.1 : ISD4002 SS pin
                             '         PORTB.2 : ISD4002 SCLK pin
                             '         PORTB.3 : ISD4002 MOSI pin
                             ' PORTB Input on :
                             '         PORTB.0 : ISD4002 INT pin
                             '         PORTB.4 : ISD4002 MISO pin
                             '         PORTB.5 : ISD4002 RAC pin
                             '         PORTB.6 : "SETUP" button
                             '         PORTB.7 : "RECORD" button
    Later to write to the ISD chip, i used
        ss = 0
        shiftout MOSI,SCLK,LSBFIRST,[ISDword\16]
        ss = 1
    to read from
            ss=0
            shiftin miso,sclk,lsbpre,[isdpointer\16]
            ss=1
    HTH
    Bakari's Avatar
    Bakari Guest
    Default Asking for Code
    Dear mister_e,
    Thanks for your support. Could you please send me your code that used for controlling ISD4002. The one that includes the recording and playing back as well as the interrupt routine and the EOM one.
    Waiting for your help, please
    Best regards,
    Bakari
    Bakari's Avatar
    Bakari Guest
    Default Asking for additional support
    Dear Member,
    Could you please tell me why you need to connect the interrupt pin from ISD4002 to the microcontroller while you can read the EOM or OVF flag from the MISO register? Also, why are you connecting the RAC pin? I think it’s possible to keep it floating. Finally, is it required to set a frequency for the SCLK pin from the microcontroller or they will communicate by default without setting any clock?
    All my questions are based on my understanding. If there is any thing wrong please inform me. I am sorry for disturbing you. Thanks again for your help.
    Best regards,
    Bakari
    for the code... sorry i can't post this one. It's prop to a customer but i remind to see some example here... do a search and you'll find them
    Yes you can skip the INT pin and read the EOM instead, same for RAC.
    I used them to make things simple and retrieve the begin and end address of each message.
    ISDs chips are close to be great, the only kind of bug if those 4002, is the pop sound at the begining and at the end... wich can be resolved in hardware... one reason of the RAC and INT.
    You don't need to bother about the SCLK frequency... it will work. It's a synchronous communication, not like a simple SERIN/SEROUT where the baudrate is important.
    Bakari's Avatar
    Bakari Guest
    Default ...... Thanks ......
    Dear mister_e,
    I am sending this email for you to say thanks a lot for your great efforts (no other questions up to now)... Thaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa aanks.
    Yours,
    Bakari
    Cambridge UK
    Quote Originally Posted by mister_e
    I am having problems with the pop sound can you let me know how you resolved it please? I found a data sheet from winbond giving a solution to the pop when recording, but not during the play back.
    Nick
    That's a pain, the only way i found was to monitor the address and use a extra mute circuit just before the EOF Interrupt.
    Cambridge UK
    I was thinking of turning the audio amp off a few milli seconds before the pop,
    If I record the output audio of the 4002 back to my laptop I can use audio software to determine the average pop time and power down the lm386 before it happens.
    When I saw the bit about RAC and INT I thought you might have a way controlling it via the software.
    Nick
