Ask For Help
Results 1 to 19 of 19
Thread: Ask For Help
    Yup that's an oldie... how about finding an old Texas Instrumens ti-99/4a speech module
    If it's just human words, there's probably some text-to-speech ICs somehow somewhere over the web... sure it must exist. If my memory is good Winbond do some.. but... DUH! Google!
    EDIT: nice link Alain..
    Talking Oldies
    Hi, Steve
    My HP86 with all its peripherals is still alive ...
    Ti doesn't speak HP language !!! No Ti home ...
    Still useful at home: Unicom 202SR , HP29 ... and the first HP Scientific calculator !!! ( The model 34 ? )
    Winbond = $$$$$$ ...
    maybe, if not too much words used, an ISD could be used here ...
    Cheers, Alain
    PS: I found another juke-box "asm include" program ... straight from HTTTP format !!! converter utility comes with.
    Bakari's Avatar
    Bakari Guest
    Red face Thanks for support
    Dear members,
    Thanks a lot for your support. In fact I have started with the suggestions of mister_e to use ISD4002 with PIC16F877. In fact, while I am reading about it, I faced a lot of difficulties in the part of programming it and interfacing it with PIC16F877. Therefore, it will be great if you provide me with an illustration about these points and detailed steps for recording and playing saved voice messages.
    Best regards,
    Bakari
    Bakari's Avatar
    Bakari Guest
    Default Help me, I am in trouble.
    Dear Members,
    Can any body show me the connection between PIC16F877 and ISD4002. I connected them and nothing is working. I have decided to start the troubleshooting with the connection. My connection was as follow (both have ICs DIP pachaging):
    PIC16F877 ISD4002
    Pin 18 Pin 28
    Pin 23 Pin3
    Pin 24 Pin 2
    Pin 1 in ISD4002 is connected to ground because I need it always in slave mode. Pin 7 in PIC16F877 is connected to Vcc since I need it always in master mode.
    Looking for any help.
    Best regards,
    Bakari
    To make things simple, you'll need to use SHIFTIN/SHIFTOUT in PBP. so it doesn't really matter the PIC I/O you use.
    A while back i used a PIC16F628, Bellow is the hardware assignement i used.
        ' I/O Definition
        TRISA = %00110000    ' PORTA Output on :
                             '         PORTA<3:0> : LCD data
                             '         PORTA<7:6> : LCD RS & E bit
                             ' PORTA Input on :
                             '         PORTA.4 : "ALT PLAY" Button
                             '         PORTA.5 : "PLAY" button
        TRISB = %11110001    ' PORTB Output on :
                             '         PORTB.1 : ISD4002 SS pin
                             '         PORTB.2 : ISD4002 SCLK pin
                             '         PORTB.3 : ISD4002 MOSI pin
                             ' PORTB Input on :
                             '         PORTB.0 : ISD4002 INT pin
                             '         PORTB.4 : ISD4002 MISO pin
                             '         PORTB.5 : ISD4002 RAC pin
                             '         PORTB.6 : "SETUP" button
                             '         PORTB.7 : "RECORD" button
    Later to write to the ISD chip, i used
        ss = 0
        shiftout MOSI,SCLK,LSBFIRST,[ISDword\16]
        ss = 1
    to read from
            ss=0
            shiftin miso,sclk,lsbpre,[isdpointer\16]
            ss=1
    HTH
    Bakari's Avatar
    Bakari Guest
    Default Asking for Code
    Dear mister_e,
    Thanks for your support. Could you please send me your code that used for controlling ISD4002. The one that includes the recording and playing back as well as the interrupt routine and the EOM one.
    Waiting for your help, please
    Best regards,
    Bakari
    Bakari's Avatar
    Bakari Guest
    Default Asking for additional support
    Dear Member,
    Could you please tell me why you need to connect the interrupt pin from ISD4002 to the microcontroller while you can read the EOM or OVF flag from the MISO register? Also, why are you connecting the RAC pin? I think it’s possible to keep it floating. Finally, is it required to set a frequency for the SCLK pin from the microcontroller or they will communicate by default without setting any clock?
    All my questions are based on my understanding. If there is any thing wrong please inform me. I am sorry for disturbing you. Thanks again for your help.
    Best regards,
    Bakari
