PBP Editor Wish List:
Results 1 to 8 of 8
    Feb 2003
    Quote Originally Posted by mister_e
    Melabs don't create the Editor. If you have MicroCode Studio... all the credit goes to Mr David Baker from Mecanique.... yeah the same guy who create at least the Free Easy HID Maker.
    All excellent an used daily by myself. Thank you David for such great stuff!
    David is also a member of this forum, his website is bellow.
    www.mecanique.co.uk
    I agree.
    Microcode Studio Plus is superb but I also agree with the first point raised by the original poster as by far my biggest mistake is putting "END IF" instead of "ENDIF"
    What I would like to see added to MCS is the ability to insert "Page Breaks" into the source code so that a printout can be made to look neater, eg force a new sheet before a particularly long section of code to stop it appearing over two pages.
    Keith
    www.diyha.co.uk
    www.kat5.tv
    the only thing you can do, is to import your .BAS to Word and do all formating there. But your point is interesting.
    blainecf's Avatar
    blainecf Guest
    Default One more improvement request for PBP: String Assignment to an array
    Since this is possible:
    MyArray VAR BYTE[20]
    MyArray[0] = "H"
    MyArray[1] = "i"
    MyArray[2] = " "
    MyArray[3] = "B"
    Why not:
    MyArray[0] = "Hi Blaine"
    and then
    MyArray[3] = "Rhonda"
    I'm not asking for full blown BASIC variable length string handling capabilities with garbage collection, but this one piece of functionality would be WONDERBAR!!!
    MyArray[0]="String" will never work as each index must be a byte. but
    MyArray var byte[20]
    MyArray="String"
    could be interesting. But as i don't really use array for string but prefer the 'embedded string in your code space' style or using an external eeprom... i can't see any benefit of... but maybe if
    Array2 var byte[20]
    MyArray="Hello"
    Hserin [STR Array2\20\13]
    If array2=Myarray then DoSomething
    now we talk of something easy to write and understand... usefull... yeas, no, toaster, hamburger... depending the way you think.
    blainecf's Avatar
    blainecf Guest
    Default String assignments to arrays
    Has anyone written assembler functions that would stuff strings into arrays?
    If someone would give me the basics of it, I'd love to write a set of low-level string functions for manipulating strings withing PBP arrays. Someone please help me get to first base and I'll run with it, posting the results as I go !
    Just show me how to accomplish: MyArray = "Hi Blaine" via something like:
    call stringassign MyArray, "Hi Blaine"
    Then I'll try to write corresponding functions for mid, left, right, and concatenation. We'll debate, refine, and GO FORWARD CONQUERING!
    you can play around the 'embedded string in your code space' stuff
    http://www.pbpgroup.com/modules/wfse...p?articleid=10
    just change the StringOut subroutine to send value to an array instead of sending it with HSEROUT.
    it's still far of what you need but have a look at different method...take your time to read from the begining'till the end. You need the use of Macro.. there's few example in and there
    http://www.picbasic.co.uk/forum/show...rings+embedded
    and now we are far of the original topic
  1. PBP Book
    By Bruce in forum Off Topic
    Last Post: - 4th October 2021, 12:55
  2. PBP List file???
    By MOUNTAIN747 in forum General
    Last Post: - 28th February 2010, 19:48
  3. List of instructions used in PBP ?
    By AndrewC in forum mel PIC BASIC Pro
    Last Post: - 2nd November 2007, 11:22
  4. PBP wish list.....
    By muddy0409 in forum PBP Wish List
    Last Post: - 21st November 2005, 09:51
  5. PBP Wish List
    By Radiance in forum PBP Wish List
    Last Post: - 1st February 2005, 17:30
