Port A pins
Results 1 to 4 of 4
Thread: Port A pins
Threaded View
  1. #2
    Few start point
    http://www.picbasic.co.uk/forum/show...hlight=dummies
    ;	Super dooper LED blink with 10F200
    ;	Steve Monfette
    ;	Mister E
    ;	23/03/2006
    ;	As if the world really needed it... well it's still usefull
    ;	to learn a bit how to play and waste your time using the
    ;	annoying assembler language.  BTW 10F200 are just too small
    ;	to accept any other language.
    ;	This program will use a software loop delay, called by a macro
    ;	wich will pass the delay to produce... at least not too basic and
    ;	some part could be usefull.. one day if someones really try to figure
    ;	out how it works... just kidding.. i know EVERYBODY WILL TRY ;o)
    	INCLUDE "P10F200.INC"	; load all needed stuff
    ;	PIC configuration
    	__Config _MCLRE_ON & _CP_OFF & _WDT_OFF
    ;	Hardware assignement
    	#define Led			GPIO,2
    ;	RAM assignement
    ; 	hands-up those who discover figure 4-3
    	cblock 0x10
    		loop
    		UserDelay
    	endc
    ;	Macro Definition
    ;	Be carefull, the following macro is extremely difficult to understand
    ;	and contain tons of information... always refer to MPASM book to
    ;	understand all trick it do.. mpff mkay i stop it :o)
    ;	Nothing fancy, the macro will just pass the parameter to the 1 msec
    ;	subroutine -> Delay <- Not much.  What could she do more to be still
    ;	code efficient anyway?
    Delayms	macro User
    	movlw	User		; put User wish somewhere
    	movwf	UserDelay	; copy it to something
    	call 	Delay		; do the delay
    ;					Program Begining
    ;	Hardware configuration
    	ORG 0			;
    	movwf	OSCCAL		; Load OSCCAL value
    	movlw	b'11111011' 	;
    	TRIS	GPIO		; Set GP2 as Output
    	movlw	b'11011111' 	; TOCS=internal => to use GP2 as Output
    	OPTION			; => datasheet section 4.5
    ;	Tha ****!
    ;	The exciting part of the program... how to blink a LED
    Start
    	bsf 	Led		; Enable LED
    	Delayms d'250'		; do 250 mSec Delay
    	bcf		Led	; Disable LED
    	goto 	Start		; Have fun forever, enjoy the show
    ;	Delay Subroutine
    ;	The main program call the macro, the macro call this routine
    Delay
        	movlw   d'250'		; 1 mSec base
        	movwf   loop  		;	loop
       	;	DelayLoop
        	nop  			; do nothing                (1 Cycle)
        	decfsz  loop,f	    	; base loop finished?       (1 cycle if NO, 2 cycle if YES)
        	goto    $-2 	  	; NO... jump 2 lines before (2 cycles)
        				;               Killed about 4 cycles * 250times @1uSec = 1mSec
        	decfsz	UserDelay,f 	; DelayFinish?
        	goto 	$-6		; NO... do it again, jump 6 line before
        	retlw	0		; Astalavista baby
  1. Indexing Port Pins
    Last Post: - 5th January 2014, 08:31
  2. Pointers To Port Pins ?
    By BitHead in forum mel PIC BASIC Pro
    Last Post: - 23rd December 2009, 20:38
  3. Change On Interrupt, PIC16F884
    Last Post: - 14th November 2008, 17:25
  5. PIC PORT 'special' pins
    By barkerben in forum General
    Last Post: - 18th January 2005, 21:40
