HSEROUT Newbie question/problem
Results 1 to 13 of 13
    Mark Scotford's Avatar
    Mark Scotford Guest
    Steve, I get this out, and I have my Serial Communicator set up the same as the prevous posters
    à€pÇàŽøàŽàøààŽpÇàŽüàŽàpÇàŽøàŽàøà àŽüüøàŽàøàŽàpÇàŽpÇàŽààŽüàŽàpÇàŽøàŽ àøààŽpÇàŽüàŽàpÇàŽpÇàŽøàŽàøààŽüü øàŽàøàŽàpÇàŽpÇàŽààŽüàŽàpÇàŽøàŽàøà àŽpÇàŽüàŽàpÇàŽpÇàŽøàŽàøààŽüàŽàpÇàŽøàŽ àøààŽpÇàŽààŽüàŽàpÇàŽøàŽàøààŽpÇ àŽüàŽàpÇàŽpÇàŽààŽ
    Oct 2003
    holland
    Is your powersupply oscillating?
    Did you mount a capacitor over the supply points of the chips?
    Mark Scotford Guest
    Yep, all chips have a 104 Cap near-by. Hold fire a while on this problem chaps. I tried programming an EPROM version of the processor instead of using my beloved ICEPIC2, and I am getting nothing happening, unfortunetly I have to go out now, but will continue tomorrow.
    Mark Scotford Guest
    Appologies are due, especially to Steve and Matt. I made the fundamental mistake of believing what I was being told, a colleague said he had given me a known working board. The problem was the Loading Caps on the Oscillator crystal were of the wrong value (too high a value) which were not enough to completely cripple my ICEPIC2 but were enough to affect the speed.
    I am now getting comms. and I did that thing of jumping up and down when the word "hello" appeared in Serial Communicator.
    Thanks to everybody who helped and sorry if I wasted your time.
    Mark Scotford Guest
    Just as a side issue, I plugged my ICEPIC2 back in, and I got garbage out again, on checking I find that ICEPIC2 uses its own clock of 4Mhz, (in my defence I got this secondhand so I do not have the manual) 4Mhz is the frequency I normally use on my PIC projects, so it has not been an issue before. Anyway just changed the crystal to 4Mhz, changed the settings in my code, run ICEPIC2 again and everything is working fine, so I am off and running, thanks to all.
    may happen dude. Nice to know you find the problem and learned from it.
    Have fun!
  1. I2C Slave with a PIC
    By ralfmayr in forum mel PIC BASIC Pro
    Last Post: - 21st August 2016, 18:44
  2. hserin and sms controller
    By xxxxxx in forum mel PIC BASIC Pro
    Last Post: - 10th February 2010, 16:49
  3. HSEROUT and Commas, What? Help Me Understand
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2009, 20:12
  4. Is HSEROUT corrupting bit 7 ?????
    By Robert Wells in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2008, 17:26
  5. Controlling an 240x128 LCD Touchpanel Display
    By Vincent in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 00:36
