Don't blow your fingers off with this PIC idea
Results 1 to 11 of 11
    Nov 2004
    Saskatchewan Canada
    Testing of remote igniton was a success. A model rocket igniter easily sparks a fuse using 4 AA batteries and 20 feet of wire.
    The next step in fuse regard is making repeat and reliable connections between the igniter and the fuse itself.
    A little Google search finds that I am not so crazy after all. I've found sites where people are making fuses and gadgets to both hold and lauch various consumer fireworks. I haven't found anyone using a computer and PIC controller to make it all automated, but many manual controllers are out there.
    Anyone else have any ideas on possible components? I'm thinking now that 16 lines is not enough. Thirty-two would be more reasonable for a good show. Also, one line may need to ignite 5 or 6 fuses at once so the current needs to be enough on those lines not to fry the contoller, but send enough juice down the wire to spark all those fuses at once.
    An ability to link 16 line system together may be a better solution. In this case using different tones to talk to each 16 line system might work well.
    Bart
    Smile
    Relays or MOSFET could be a good choice to drive the igniter. Look at your local part supplier if you could find some overstock relay. I found some in here 10Amp rated, 5V coils for less than 2$.
    32 outputs... why not. Many 40Pins device gives you 33 i/o. 1 left for the audio input... just perfect. OR, using a smaller one with an i/o expander... in this case you don't just add extra part... but also a little bit of delay... but few ms will never ruine the show. In another hand, if one day you decide to add other outputs, you just need to add extra i/o expander.
    Let's say a PCF8574, give you 8 i/o and you can use 8 of them on the same I2C bus... 64 outputs.. not bad.
    A pic 12F would do the job, leaving few i/o for audio and stuff.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. Replies: 67
    Last Post: - 8th December 2009, 03:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
