Don't blow your fingers off with this PIC idea
Results 1 to 11 of 11
    Feb 2003
    Quote Originally Posted by bartman
    A system to safely set off consumer grade fireworks.
    Issues:
    2) Safety mechanism - There could be NO chance of power going to the igniters at any time other than when commanded. No output spike when first turned on or anything like that.
    Given that you are having long cables connected to your PIC both firing the igniters and supplying the audio to sequence the show, how are you going to adequately protect the system from RFI pickup.
    A signal from a mobile phone or taxi radio etc could cause the system to behave erratically and fire an igniter at the wrong time.
    Whilst I agree that it could be a really cool thing to develop, the potential for serious injury is something that should be considered VERY SERIOUSLY. Personally I believe that this is something that should remain in the domain of the Professional events organisers.
    By their very nature "consumer" firework parties tend to be relaxed affairs often with the presence of alcohol and an automated display would have to have an "Emergency Stop" function in case someone strayed into the area of a firework or if a rocket fell over just as it was about to be fired.
    I have been to organised displays where things havent gone according to plan and had a rocket miss me by a couple of feet
    Keith
    www.diyha.co.uk
    www.kat5.tv
    Nov 2004
    Saskatchewan Canada
    Stop being a party pooper! :-)
    I'm not planning on putting on any shows outside of my own yard in a rural area. This is just a fun little device to think about.
    The only long wire is the one from the CD player to the controller. The controller would only be a couple feet away from the fireworks. Emergency off is stopping the CD I think. No tone going to the controller.
    I actually think it is safer this way than someone standing within 10 feet lighting fuses one by one or getting bold and trying to light 3 or 4 at once and having one go off in their face. This system has everyone 100 feet away or more.
    Bart
    Jul 2006
    Southern California, U.S.A.
    If you are looking for a way of decoding touch tones, I suggest using the 8870 chip available from BG micro in Texas. It is a very simple to use 18 pin DIP chip and converts touch tones from a telephone or receiving radio into a 4 bit binary code. I use it for remote control projects. It works flawlessly every time! It only needs about 5 extra components such as resistors, a crystal oscillator and a few capacitors. Speaking of which, I need help on another project. Please see my posted question I left on 7-15-2006 under the user name "Madscientist". I am brand new to this site.
    Darren
    Nov 2004
    Saskatchewan Canada
    Testing of remote igniton was a success. A model rocket igniter easily sparks a fuse using 4 AA batteries and 20 feet of wire.
    The next step in fuse regard is making repeat and reliable connections between the igniter and the fuse itself.
    A little Google search finds that I am not so crazy after all. I've found sites where people are making fuses and gadgets to both hold and lauch various consumer fireworks. I haven't found anyone using a computer and PIC controller to make it all automated, but many manual controllers are out there.
    Anyone else have any ideas on possible components? I'm thinking now that 16 lines is not enough. Thirty-two would be more reasonable for a good show. Also, one line may need to ignite 5 or 6 fuses at once so the current needs to be enough on those lines not to fry the contoller, but send enough juice down the wire to spark all those fuses at once.
    An ability to link 16 line system together may be a better solution. In this case using different tones to talk to each 16 line system might work well.
    Bart
    Smile
    Relays or MOSFET could be a good choice to drive the igniter. Look at your local part supplier if you could find some overstock relay. I found some in here 10Amp rated, 5V coils for less than 2$.
    32 outputs... why not. Many 40Pins device gives you 33 i/o. 1 left for the audio input... just perfect. OR, using a smaller one with an i/o expander... in this case you don't just add extra part... but also a little bit of delay... but few ms will never ruine the show. In another hand, if one day you decide to add other outputs, you just need to add extra i/o expander.
    Let's say a PCF8574, give you 8 i/o and you can use 8 of them on the same I2C bus... 64 outputs.. not bad.
    A pic 12F would do the job, leaving few i/o for audio and stuff.
  1. SMS via pic
    By kenandere in forum GSM
    Last Post: - 10th March 2010, 11:00
  2. Replies: 67
    Last Post: - 8th December 2009, 03:27
  3. HSERIN & Interupts (aka controlling PIC programs from a remote PC)
    Last Post: - 17th June 2009, 15:46
  4. pic to pic ir link versus wired link : help please anyone
    Last Post: - 30th May 2008, 22:01
