Newbee What is missing? hpwm still won't compile in pbp syntax errors
Results 1 to 3 of 3
    Jun 2006
    Default Newbee What is missing? hpwm still won't compile in pbp syntax errors
    16F877 at 4 mhz
    Begin:
    PVAL = 1000 ' Start with 1kHz
    For Duty = 64 to 250
    HPWM 1,Duty,PVAL
    PAUSE 100
    NEXT Duty
    Duty = 127 ' 50% Duty-cycle
    For PVAL = 1000 to 10000 step 100 ' Increments of 100. Change as needed
    HPWM 1,Duty,PVAL
    PAUSE 100
    Next PVAL
    GOTO Begin
    New Jersey
    You have to define your oscillator:
    Then you have to define PVAL and DUTY:
    PVAL VAR WORD
    DUTY VAR BYTE
    Add these to the top of your program and try it.
    Chris
    Jun 2006
    That did the trick Thank you so much Chris!
  1. Unable to pass a variable to LCDOUT without getting compile errors
    By Ferroto Baggins in forum mel PIC BASIC Pro
    Last Post: - 28th February 2010, 17:43
  2. Endless supply of 'syntax error's.
    By BitHead in forum mel PIC BASIC Pro
    Last Post: - 14th December 2009, 21:21
  3. sound command & music
    By trying in forum mel PIC BASIC Pro
    Last Post: - 26th May 2006, 15:14
  4. 3 HPWM channels
    Last Post: - 4th April 2006, 03:43
  5. Newby- PBP wont compile for 18F (MPLAB)
    Last Post: - 18th December 2005, 00:30
