microcode studio
Results 1 to 12 of 12
    cable tech's Avatar
    cable tech Guest
    Cool microcode studio
    how do we add to the targeted pic selection, i'm programming a 16f690 but no target device is in the pulldown menu for it?
    john
    it's suppose to be done automatically ... well in MCSP.
    Case you want to add a device, open the PIC.INI file and add it in
    SWITZERLAND (french speaking)
    Default microcode studio - add new device in v4.0.0.0
    How do I add a new device in MCS v4.0.0.0 please?
    I'd like to use PIC18F26K80 but it is not in its device (drop-down)list.
    I can't find in my computer any of PIC.INI or DEVICE.ini files described in other threads or founds on the web, adding *.BAS or *.INC files in PBP doesn't seem to work either
    Roger
    Default Re: microcode studio
    Support for the PIC18F26K80 was added in PBP version 2.60C, and MCS should pick up on this if you have a version of PBP that supports the PIC18F26K80.
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    I may need to upgrade my PBP.
    Thanks for the info.
    Roger
    If you have the free version of MicroCode Studio, it supports 16F877A, 18F25K20, 16F887, 18F452, 18F4520 PICs.
    (I just happened to research this in the chat just now)
    Jul 2009
    Worcester South Africa
    How do you make Microcode studio work in Win 7 with a 64 bit system? My MCS does not want to compile, just give me nasty message.
    What is the message? What is the version?
    You should not have a problem.
    From the ChatBox
    I have problems with Micro code Studio it does not want to compile. I upgraded my computer to Win 7. so there is a fault message "incompatability with windows 64 bit".
    Compile with MPASM instead of PM.
    Default microcode studio - PICKit2 doesn't support PIC18F26K80
    I'd like to use PIC18F26K80...
    I just learned from MICROCHIP that this PIC is not supported by my PICKit2 programmer which, btw, is already considered as obsolete = no update in sight.
    New PBP + new programmer = pfffff......what's next?
    Roger
    Default Re: microcode studio - PICKit2 doesn't support PIC18F26K80
    Maybe another new PBP for 24F series and a new pogrammer again???
    In that case I sure am gonna update
    Jul 2009
    Thanks for the reply but I manage to fix the problem, re install Win7 with x86 (32 bit).
    Windows; the best virus ever written.
  1. Interrupt & device setup for a PIC16F628A in Microcode Studio Plus
    By wildpikachu in forum mel PIC BASIC Pro
    Last Post: - 3rd May 2008, 16:28
  2. Microcode studio loader problem
    By woodygjw in forum General
    Last Post: - 10th September 2007, 01:18
  3. Microcode studio and USB pics
    By KPDes in forum mel PIC BASIC Pro
    Last Post: - 27th May 2007, 09:28
  4. Replies: 2
    Last Post: - 9th February 2006, 22:03
  5. How to used ICD of microcode studio
    Last Post: - 19th November 2005, 00:29
