Hey CocaColaKid, thanx for the code it worked, however, I suggest an improvement as stated in the DS1302 datasheet U R supposed to read
the seconds again at the end in case the second ticks over from 59 to
00 while you were reading the mins, hrs, etc. this could result in erroneous
Real Time reading.
Suggest modification here:
ss var byte 'seconds
ss2 var byte 'seconds comparison byte
start:
reg_adr = readsec ' Read seconds
gosub w_in
ss = mem
reg_adr = readmin ' Read minutes
gosub w_in
mm = mem
reg_adr = readhour ' Read Hours
gosub w_in
hh = mem
reg_adr = readyear ' Read Year
gosub w_in
yr = mem
reg_adr = readdate ' Read Date
gosub w_in
date = mem
reg_adr = readmonth ' Read Month
gosub w_in
mo = mem
gosub w_in
ss2 = mem
IF ss <> ss2 THEN start 'COMPARE FIRST AND SECOND READINGS AND TRASH IF DIFFERENT.
lcdout $fe,1,"TIME:",HEX2 hh,":",HEX2 mm,":",HEX2 ss
goto start
Cheers, Art.
