real time clock
Results 1 to 40 of 45
Thread: real time clock
    Quote Originally Posted by shahidali55 View Post
    It really puts all the PBP routines off . . .
    LCDOUT takes like 3 seconds to print 16 digits . .
    Which is exactly what I'd expect...unless you write the code in assembly, PBP will time everything like it was running 4Mhz. Maybe try 'lcd_commandus' and lcd_dataus' both set to 1 and see if it works like that at 32khz.
    Which PIC are you using this time?
    There is a clock switching feature in most newer PICs these days, can switch between the main (4Mhz or whatever) and the internal 32/37/40khz (depends on the datasheet you're looking at) 'backup' oscillator if configured correctly. I use it all the time to save power.
    Jun 2006
    Bangalore, India
    I'm using a 16F84A so there is no question of internal oscillator.
    I tried several other things besides LCDOUT. Even FOR and WHILE statements take a lot o ftime to execute . . .
    I used a external 32.768Khz oscillator.
    Just to verify that the F84 was running at 32.768Khz, i tried a clock code on it and it does keep accurate time . . . down to a second a day.
    I'm using a 16F84A so there is no question of internal oscillator. I tried several other things besides LCDOUT. Even FOR and WHILE statements take a lot o ftime to execute . . . I used a external 32.768Khz oscillator. Just to verify that the F84 was running at 32.768Khz, i tried a clock code on it and it does keep accurate time . . . down to a second a day.
    If you're running 32.768khz, everything is going to take a lot longer to execute.
    The clock is 32.768khz, but the PIC is only executing instructions at 8.192khz (Fosc/4), and if you're code has a lot of call's, gosub's, returns, anything that takes the code to 'somewhere else', it'll run half that fast again (4.096khz, Fosc/4 + one extra instruction for each 'somewhere else').
    So, what are you asking? What's the point?
    Jun 2006
    Bangalore, India
    I think i'll stick to 4Mhz for now . . .
    Unhappy enabling trickle charging
    this is a very belated response to shahidali55.
    I've added a tiny bit of code to "ds1302_user_interface.txt" to enable trickle charging. This is a small feat, but helped me understand how the register addressing and definitions are used.
    edit: I'm using a 5v 0.47f supercap which doesn't need diodes or resistors, so "trickledef" below uses a bit sequence 1010 (for TCS) 00 (for DS) and 00 (for RS), see page 7 of the DS1302 datasheet for other options
    cheers,
    Tobie
    'additional variables
    writechrg var byte
    tricklereg var byte
    writechrg = $91 'Write Command for the trickle register
    trickledef = $A0 'definition for a supercap which uses no diodes or resistors
    ' this goes in the "setup" subroutine, not as the statement first or last though
    reg_adr = writechrg
    outbyte = tricklereg
    gosub w_out
    Default Supercap
    hi,
    here's a modified version with trickle charge enabled for a supercap. Note this includes no LCD interface.
    A schematic is included in this pdf http://www.parallax.com/dl/appnt/jav2/appnote2.pdf
    Here's a datasheet for the supercap, I used the 0.47f component: http://rocky.digikey.com/WebLib/Coop...capacitors.pdf
    Jan 2007
    Question Alarm Time Problem
    Hi Melanie,
    I used your code MN1307.txt which is very good coded and easy to understand. I just want to add some alarm time. I know and did with some if...then...endif way.
    Now simply it works on alarm set time but output (portb.7) blinks and do not High permanently. I tried to find some solution but it is very simple that there should not be any problem with if...then...endif. But I think it is somethink with hardware related.
    Please help me in this regard because I must need this Alarm Clock. Thanks in anticipation.
    Best Regards,
    Shahzad
  1. Real Time Clock
    By in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2012, 05:52
  2. real time clock - PCF8583
    By maria in forum mel PIC BASIC Pro
    Last Post: - 15th April 2010, 16:41
  3. Real time clock ICs
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 20th October 2008, 17:05
  4. Real Time Clock
    Last Post: - 8th December 2006, 03:02
  5. Real time clock... what a headache!
    Last Post: - 8th June 2006, 22:56
Members who have read this thread : 4
