real time clock
Results 1 to 40 of 45
Thread: real time clock
    Probably your Clock Halt flag is set..... it's undetermined when you put power on the RTC. Just clear this bit and you'll see oscillation on your scope.
    The problem is the same on many RTC. See the secondes register for the CH bit.
    Many cheaper probe will screw the signal coming from an Crystal. Place it on 10X and this will help a bit in many case.
    Jan 2006
    Istanbul
    Cool RTC - DS1302 with User Interface
    Here is a modified version of the code posted by CocaColaKid above.
    In the code above, the clock can only be set during the programming of PIC.
    With the modification here, the user can set the time, date etc. at any given time.
    Advise/post any additions, recommendations, modifications etc if any.
    Jan 2006
    Istanbul
    Cool Shorther HEX convertion sub routine
    As members are asking;
    Attached is the updated version with more space.
    (HEX Conversion is shorter)
    Jun 2006
    Bangalore, India
    Exclamation
    Hey CocaColaKid,
    Your code for the DS1302 is really good and efficient...
    I got a few questions,
    how should i enable the trickle charge option ?
    and how should i clear or set the clock halt flag???
    Jan 2006
    New Hampshire, USA
    I am a neophyte at programming, but have been writing BASIC code for 40 years. This is how I would do the conversion:
    DECX VAR BYTE(59)
    A VAR BYTE
    B VAR BYTE
    C VAR BYTE
    FOR B = 0 TO 59
    FOR A = $0 TO $59
    IF C = B THEN DECX(C) = A
    C = C+1
    NEXT A
    NEXT B
    ' THIS ROUTINE GENERATES AN ARRAY WHERE
    ' DECX(0) = $0
    ' DECX (1) = $1
    ' ETC.
    I didn't do it correctly the first time, this is better.
    blainecf's Avatar
    blainecf Guest
    Talking Straight-forward RTC bits conversion algorithm
    For all you old timers, here's an alternate way of calculating Human Date/Time from the RTC bits:
    (Also, because all info is read in one shot, there is less liklihood that the seconds won't match the minutes.)
    I2CREAD DPIN,CPIN,RTC,I2C_Adr_B,[Rd_seconds, rd_minutes, rd_hours, Rd_DOW, Rd_DAy, RD_month, Rd_Year] ' in bcd code
    Seconds = Rd_Seconds.0 + (Rd_Seconds.1 * 2) + (rd_seconds.2 * 4) + (rd_Seconds.3 * 8) + (rd_seconds.4 * 10) + (rd_seconds.5 * 20) + (Rd_Seconds.6 * 40)
    Minutes = Rd_Minutes.0 + (Rd_Minutes.1 * 2) + (rd_Minutes.2 * 4) + (rd_Minutes.3 * 8) + (rd_Minutes.4 * 10) + (rd_Minutes.5 * 20) + (Rd_Minutes.6 * 40)
    Hours = RD_Hours.0 + (Rd_hours.1 * 2) + (rd_hours.2 * 4) + (rd_hours.3 * 8) + (rd_hours.4 * 10)
    am_pm = rd_hours.5
    dow = rd_dow
    day = rd_day.0 + (rd_day.1 * 2) + (rd_day.2 * 4) + (rd_day.3 * 8) + (rd_day.4 * 10) + (rd_day.5 * 20)
    Month = rd_month.0 + (rd_month.1 * 2) + (rd_month.2 * 4) + (rd_month.3 * 8) + (rd_month.4 * 10)
    Year = rd_year.0 + (rd_year.1 * 2) + (rd_year.2 * 4) + (rd_year.3 * 8) + (rd_year.4 * 10) + (rd_year.5 * 20) + (rd_year.6 * 40) + (rd_year.7 * 80)
    I suppose that might work. But it wouldn't be my first choice.
    Only 30 or 40 times the needed code.
  1. Real Time Clock
    By in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2012, 04:52
  2. real time clock - PCF8583
    By maria in forum mel PIC BASIC Pro
    Last Post: - 15th April 2010, 15:41
  3. Real time clock ICs
    By Eng4444 in forum mel PIC BASIC Pro
    Last Post: - 20th October 2008, 16:05
  4. Real Time Clock
    Last Post: - 8th December 2006, 02:02
  5. Real time clock... what a headache!
    Last Post: - 8th June 2006, 21:56
Members who have read this thread : 4
