Strangw results when using PWM command
Results 1 to 21 of 21
    malc-c's Avatar
    malc-c Guest
    Thanks mate for your further help,
    The reason I opted for using a zenner, was the last time I used a 7805 to run a few LEDs the thing glowed trying to disapate the heat !
    I'll see if changing the resistor does the trick
    Malc
    7805 is 1Amp rated
    78L05 ~100mA
    malc-c's Avatar
    malc-c Guest
    Steve, went the hole hog and dropped in a 68R and it works a treat !!
    Thanks for your help
    Cheers
    You're welcome... just make sure that your Zener and resistor are rated to handle it ...
    Resistor 68ohm... (12-5)/68=103mA, 103mA*103mA * 68 = 0.72W => 1 watt
    Zener 5 Volt : 5*103mA = .515 Watt => could be 1/2 watt... i calculate the worst case, VMax,No Load
    Wink Good old bulbs ...
    Hi, Malc
    I just tried this ... good for bulb lamp- like ... an rather simple.
    DEFINE OSCCAL_1K 1
    ADCON0 = 0
    ANSEL = 0
    CMCON = 7
    TRISIO = %00001000
    led var GPIO.0
    i var byte
    y var byte
    Speed var word ' just if speed > 255 ...
    Speed = 100
    up:
    Pause (Speed*2)
    For i = 0 to 127
    y = SIN i
    Led = 1
    Pauseus (Speed*y)
    Led = 0
    Pauseus (Speed*( 127-y ))
    next i
    GOTO up
    Default better visual results ...
    DEFINE OSCCAL_1K 1
    ADCON0 = 0
    ANSEL = 0
    CMCON = 7
    VRCON = 0
    TRISIO = %00001000
    led var GPIO.0
    i var byte
    y var word
    up:
    Pause 200
    For i = 0 to 127
    y = SIN i
    Led = 1
    Pauseus (y*y)
    Led = 0
    Pauseus ( 16129 -(y*y) )
    next i
    GOTO up
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 20:31
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  3. turning gpio.0 high after pwm command
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 21st February 2007, 18:22
  4. Can I do this???
    By noobie in forum mel PIC BASIC
    Last Post: - 10th June 2006, 18:57
  5. Searches
    By bearpawz in forum Forum Requests
    Last Post: - 7th November 2005, 18:47
