Strangw results when using PWM command
Results 1 to 21 of 21
    That's really strange... it's working here using the first code of my previous message.
    Ramp-up, ramp-down in an endless loop... mmm.
    I suspect a hardware problem but damn it's not a really complicated hardware, i removed all the usual capacitor around, nothing on all other i/o, simple LED+300 ohm resistor... work fine. if i raise down the psu voltage... it's working from 2.5V. so uneless your Vdd rail is below or really noisy causing a RESET... i don't see why it shouldn't work.
    malc-c's Avatar
    malc-c Guest
    Steve,
    Rest assured your code works fine.. I've just breadboarded the PIC and it works, yet in the PCB ot only wants to ramp up ????? - strange !!
    I would of thought that if there was something wrong with the PCB I made (like a short) then the thing would not work full stop ! The board uses a 5.1 zenner to provide the supply to the PIC, and the output simply from GPIO 0 drives the gate of the FET and the LED - why it ramps up and not down I don't know ?
    Thanks mate.. don't waste any more of your time... I've attached the schematic just in case someone might see whats the issue ?
    assuming 12Vin and R4 is really 10K: (12-5)/10K = 0.7mA
    No problem when only the PIC run... but when the LED is attach to.. the voltage will really reduce ... 'till the PIC reset.
    your problem is there, you don't provide enough current, Zener would need at least few mA just for her +Led+Pic... Repace R4 to 200Ohm
    @12Vin : (12-5)/200=35mA
    @9Vin : (9-5)/200 = 20mA
    @12 Vin : 35mA*35mA*200Ohm = 1/4 Watt
    Or better if you replace it for a voltage regulator like 78L05 or any else
    malc-c's Avatar
    malc-c Guest
    Thanks mate for your further help,
    The reason I opted for using a zenner, was the last time I used a 7805 to run a few LEDs the thing glowed trying to disapate the heat !
    I'll see if changing the resistor does the trick
    Malc
    7805 is 1Amp rated
    78L05 ~100mA
    malc-c's Avatar
    malc-c Guest
    Steve, went the hole hog and dropped in a 68R and it works a treat !!
    Thanks for your help
    Cheers
    You're welcome... just make sure that your Zener and resistor are rated to handle it ...
    Resistor 68ohm... (12-5)/68=103mA, 103mA*103mA * 68 = 0.72W => 1 watt
    Zener 5 Volt : 5*103mA = .515 Watt => could be 1/2 watt... i calculate the worst case, VMax,No Load
    Wink Good old bulbs ...
    Hi, Malc
    I just tried this ... good for bulb lamp- like ... an rather simple.
    DEFINE OSCCAL_1K 1
    ADCON0 = 0
    ANSEL = 0
    CMCON = 7
    TRISIO = %00001000
    led var GPIO.0
    i var byte
    y var byte
    Speed var word ' just if speed > 255 ...
    Speed = 100
    up:
    Pause (Speed*2)
    For i = 0 to 127
    y = SIN i
    Led = 1
    Pauseus (Speed*y)
    Led = 0
    Pauseus (Speed*( 127-y ))
    next i
    GOTO up
  1. Active low input?
    By CosMecc in forum mel PIC BASIC Pro
    Last Post: - 8th August 2010, 20:31
  2. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 06:03
  3. turning gpio.0 high after pwm command
    By sirvo in forum mel PIC BASIC Pro
    Last Post: - 21st February 2007, 18:22
  4. Can I do this???
    By noobie in forum mel PIC BASIC
    Last Post: - 10th June 2006, 18:57
  5. Searches
    By bearpawz in forum Forum Requests
    Last Post: - 7th November 2005, 18:47
