Alain,
Yes this is to do with the "Dr Who" thread in a way. I started a new one as the matters raised in that thread (ie the fact you need to mod the inc files) resolved it.
What I can't understand was that I had used a 12F675 and the for next loops with the pwm command to successfully produce a pulsating LED for my mates project. I sent this off to him but he found that he needed to drive a bulb as the LED didn't give him the brightness he needed. I informed him that he could just used a FET and how to use a zenenr diode etc to produce 5v from a 12v battery, however he has never done any electronics, and may of fried the PIC. I then loaded up the PBP program but for some reason it stops running the down loop of the code.. anyway.. I've sent off the PCB so hopefully he hasn't fried his original PIC and he can simply drop that in and get filming
Thanks guys
