Still HSEROUT woes
Results 1 to 35 of 35
    Great!!!
    look the following link for VB code
    http://www.picbasic.co.uk/forum/misc.php?do=bbcode
    Sep 2005
    Campbell, CA
    Just to answer the random notes around the thread and also to summarize:
    The watchdog timer was disabled during programming.
    The interrupt worked exactly as expected (that is, it DID provide a 'tick' every
    millisecond).
    Writing the interrupt in pure assembly, saving Wreg,STATUS, FSR0L, and FSR0H
    produced EXACTLY the same result as using a modified "Tim Box" routine which saves the same registers as above PLUS all the PBP registers.
    Does this prove that HSEROUT cannot be interrupted? I have a question in to MELabs.
    Charles Linquist
    May 2006
    Del Rio, TX, USA
    Default Interrupts no problem with HSEROUT Here.
    Charles and Steve,
    I took Charles code and made a couple of slight changes (in italics) to accomadate a different PIC (PIC18F4620) and to send out a longer string of serial data. It ran just as expected.
    Here is the code I ran:
    DEFINE  OSC 40 'Oscillator speed in MHz: 3(3.58) 4 8 10 12 16 20 24 25 32 33 40
    ;define LOADER_USED 1
    @        __CONFIG    _CONFIG1H, _OSC_HSPLL_1H
    @        __CONFIG    _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
    @        __CONFIG    _CONFIG3H, _PBADEN_OFF_3H
    @        __CONFIG    _CONFIG4L, _LVP_OFF_4L & _XINST_OFF_4L
    ;DEFINE NO_CLRWDT 1
    DEFINE HSER_RCSTA 90H
    DEFINE HSER_TXSTA 20H
    DEFINE HSER_BAUD 9600
    DEFINE HSER_CLROERR 1
    DEFINE LOADER_USED 1 ' Bootloader
    Define USE_LFSR 1
    T0CON = %10001000
    INTCON = %11100000 ' Timer0 and Peripheral interrupts enabled
    PIE1 = %00100000 ' USART 1 receive buffer int enable
    '* Declare variables *
    W_HP_Save         var byte    BANKA  ' Save location for W in BANKA
    STATUS_HP_Save    var byte    BANKA  ' Save location for STATUS register in BANKA
    BSR_HP_Save       var byte    BANKA  ' Save location for BSR register in BANKA
    R0_2 var WORD BANKA ' PBP VARS TO SAVE
    R1_2 VAR WORD BANKA
    R2_2 VAR WORD BANKA
    R3_2 VAR WORD BANKA
    R4_2 VAR WORD BANKA
    R5_2 VAR WORD BANKA
    R6_2 VAR WORD BANKA
    R7_2 VAR WORD BANKA
    R8_2 VAR WORD BANKA
    FLAGS_2 VAR BYTE BANKA
    GOP_2 VAR BYTE BANKA
    RM1_2 VAR BYTE BANKA
    RM2_2 VAR BYTE BANKA
    RR1_2 VAR BYTE BANKA
    RR2_2 VAR BYTE BANKA
    TIMER VAR WORd
    X VAR WORD
    Y VAR BYTE
    SecondsCounter VAR BYTE
    TimerFlag VAR BIT
    KeyHitFlag VAR BIT
    DEFINE INTHAND INT_CODE 'Tell PBP Where your code starts on an interrupt
    T0CON = %10001000
    PIE1 = %00100000 ' Usart1 int enabled
    TimerFlag = 0
    Timer = 0
    X = 0
    SecondsCounter = 0
    KeyHitFlag = 0
    GOTO OVER_INT_CODE
    asm
    INT_CODE
        movwf   _W_HP_Save                 ; 1 copy W to W_HP_Save register
        movff   STATUS, _STATUS_HP_Save    ; 2 copy status reg to STATUS_HP_Save
        movff   BSR, _BSR_HP_Save          ; 3 copy BSR to BSR_HP_Save
    	MOVFF R0,_R0_2
    	MOVFF R0+1,_R0_2+1
    	MOVFF R1,_R1_2
    	MOVFF R1+1,_R1_2+1
    	MOVFF R2,_R2_2
    	MOVFF R2+1,_R2_2+1
    	MOVFF R3,_R3_2
    	MOVFF R3+1,_R3_2+1
    	MOVFF R4,_R4_2
    	MOVFF R4+1,_R4_2+1
    	MOVFF R5,_R5_2
    	MOVFF R5+1,_R5_2+1
    	MOVFF R6,_R6_2
    	MOVFF R6+1,_R6_2+1
    	MOVFF R7,_R7_2
    	MOVFF R7+1,_R7_2+1
    	MOVFF R8,_R8_2
    	MOVFF R8+1,_R8_2+1
    	IFDEF T2
    	MOVFF T2,_T2_2
    	IFDEF FLAGS
    	MOVFF FLAGS,_FLAGS_2
    	IFDEF GOP
    	MOVFF GOP,_GOP_2
    	IFDEF RM1
    	MOVFF RM1,_RM1_2
    	IFDEF RM2
    	MOVFF RM2,_RM2_2
    	IFDEF RR1
    	MOVFF RR1,_RR1_2
    	IFDEF RR2
    	MOVFF RR2,_RR2_2
    endasm
    ;%%%%%%%%%%%%%%%%%%%%%%%%% Interrupt handler written in PBP %%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%
    IF INTCON.2 = 1 THEN
    TMR0H = $EC ; Reload TMR0 to 65535 - 5000
    TMR0L = $77
    Timer = Timer + 1
    IF Timer >= 1000 THEN
    TimerFlag = 1
    IF PIR1.5 = 1 THEN
    KeyHitFlag = 1
    INTCON.2 = 0 ; Clear the timer flag
    	MOVFF _R0_2,R0
    	MOVFF _R0_2 + 1,R0 + 1
    	MOVFF _R1_2,R1
    	MOVFF _R1_2 + 1,R1 + 1
    	MOVFF _R2_2,R2
    	MOVFF _R2_2 + 1,R2 + 1
    	MOVFF _R3_2,R3
    	MOVFF _R3_2 + 1,R3 + 1
    	MOVFF _R4_2,R4
    	MOVFF _R4_2 + 1,R4 + 1
    	MOVFF _R5_2,R5
    	MOVFF _R5_2 + 1,R5 + 1
    	MOVFF _R6_2,R6
    	MOVFF _R6_2 + 1,R6 + 1
    	MOVFF _R7_2,R7
    	MOVFF _R7_2 + 1,R7 + 1
    	MOVFF _R8_2,R8
    	MOVFF _R8_2 + 1,R8 + 1
    	IFDEF FLAGS
    	MOVFF _FLAGS_2,FLAGS
    	IFDEF FLAGS
    	MOVFF _GOP_2,FLAGS
    	IFDEF RM1
    	MOVFF _RM1_2,RM1
    	IFDEF RM2
    	MOVFF _RM2_2,RM2
    	IFDEF RR1
    	MOVFF _RR1_2,RR1
    	IFDEF RR2
    	MOVFF _RR2_2,RR2
    	IFDEF T2
    	MOVFF _T2_2,T2
        movff   _BSR_HP_Save, BSR          ; Restore the BSR reg
        movf    _W_HP_Save, W              ; Restore W
        movff   _STATUS_HP_Save, STATUS    ; Restore the STATUS reg
        Retfie                             ; Exit the interrupt routine
    OVER_INT_CODE:
    Topp:
    IF TimerFlag = 1 THEN
    SecondsCounter = SecondsCounter + 1
    HSEROUT ["Seconds = ",#SecondsCounter,13,10]
    HSEROUT ["abcdefghijklmnopqrstuvwxyz1234567890ABCDEFGHIJKLMNOPQRSTUVWZYZ1234567890",_
    		rep "1"\10,rep "2"\10,rep "3"\10,rep "4"\10,rep "5"\10,13,10]
    TimerFlag = 0
    Timer = 0
    IF KeyHitFlag = 1 THEN
    HSERIN [Y]
    HSEROUT[Y]
    KeyHitFlag = 0
    INTCON.7 = 1 ; Turn global Ints back on
    Goto Topp
    Here is the output:
    So...
    I don't think it's a problem with the HSEROUT being interrupted.
  1. I2C Slave with a PIC
    By ralfmayr in forum mel PIC BASIC Pro
    Last Post: - 21st August 2016, 18:44
  2. hserin and sms controller
    By xxxxxx in forum mel PIC BASIC Pro
    Last Post: - 10th February 2010, 16:49
  3. HSEROUT and Commas, What? Help Me Understand
    By altech6983 in forum mel PIC BASIC Pro
    Last Post: - 20th July 2009, 20:12
  4. Is HSEROUT corrupting bit 7 ?????
    By Robert Wells in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2008, 17:26
  5. Controlling an 240x128 LCD Touchpanel Display
    By Vincent in forum mel PIC BASIC Pro
    Last Post: - 8th June 2006, 00:36
