Newbee Hardware PWM clarification needed
Results 1 to 4 of 4
    Jun 2006
    Default Newbee Hardware PWM clarification needed
    I found this code in the forums . And will be a good beginning for my project. What do I need to be able to compile it in PICBASIC without so many errors? A 16f877 at 4 Mhz
    Begin:
    PVAL = 1000 ' Start with 1kHz
    For Duty = 64 to 250
    HPWM 1,Duty,PVAL
    PAUSE 100
    NEXT Duty
    Duty = 127 ' 50% Duty-cycle
    For PVAL = 1000 to 10000 step 100 ' Increments of 100. Change as needed
    HPWM 1,Duty,PVAL
    PAUSE 100
    Next PVAL
    GOTO Begin
    regular PBC or PBP (pro)?
    If you didn't define the variables or you're using PBC, i don't see the error source
    PBC don't have the HPWM statement, you'll need to POKE the PIC registers as per the PIC datasheet.
    Jun 2006
    So it would work with PBP? I have the demo and it comes up with a bunch of syntax and bad expression errors Thanks Emmett
    Ok i try again..
    If you didn't define the variables ... i don't see the error source
    X Var BYte
    tada var word
    etc
    etc
  1. Variable PWM PIC18F2431
    By trr1985 in forum mel PIC BASIC Pro
    Last Post: - 12th June 2009, 07:03
  2. Hardware PWM Question?
    By jhorsburgh in forum General
    Last Post: - 18th August 2008, 04:07
  3. Inverting the o/p of hardware PWM
    By AndrewC in forum mel PIC BASIC Pro
    Last Post: - 7th August 2008, 20:36
  4. PWM: Vernacular/Function (Newbee)
    By TerryN in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2008, 17:58
  5. Help needed - MOSFET driven by PWM
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 06:02
