Many Analog Inputs
Results 1 to 12 of 12
    Hi, Ioannis
    70 pots ... wow, how much hands to drive them ??? two 8 channel low Ron multiplexers could do it ... makes 8 I/O ports
    for the keyboard ... 7 port lines can give you 42 buttons ... the trick is just to add a series diodes with each button, and swap the line levels that test the buttons.
    Total is 15 I/Os ...
    Sorry for Sayzer, but 35 resistors will really be too close a value to each others ( 3% steps ) ... will give a rock'n roll decoding !!! and we do not talk about the POT command !!!
    Default Many Analog inputs
    Thanks for the replies.
    Well for the buttons I think I 'll choose the matrix method (5x7 or more for the future).
    About analog I came up with a scheme like this:
    The pots will be grouped in 8 rows by 9 or more columns.
    One end will be grounded. The other end will be joined for every row together and powered by a PIC pin output.
    All wipers in one column will be joined together through a schotky diode and grounded by a 1M resistor, then input to a Analog multiplexer. The output of the multiplexer will be driving the A/D of the PIC.
    I know the above idea will lack precision, but this really does not matter a lot if the error is common for all pots.
    For the history, the application is a MIDI controller for a music plug-in that has on software many "analog controls" on screen. The idea is not to use the mouse to change the control but a real knob.
    Any comments welcome.
    Most multiplexer provide a low resistor between the IN/OUT, i don't see any kind of problem by using it. just make sure you smooth the signal at the output and you should be in business.
    I already done something like that with almost the same requirement. The main difference was that i used few a/d and few multiplexers and all the POT was always connected to AVdd and AVss, the output to the Multiplexer, multiplexer out to an opamp (to match 100K impedance), then to the PIC a/d.
    Have fun!
  1. Erratic analog inputs .
    By timseven in forum mel PIC BASIC Pro
    Last Post: - 10th October 2009, 23:34
  2. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  3. Multiple analog inputs ?
    By rngd in forum mel PIC BASIC Pro
    Last Post: - 25th February 2008, 16:13
  4. Help with Analog Interrupt
    By brid0030 in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 19:14
  5. analog inputs on 16F716
    By schwinn_rider in forum mel PIC BASIC Pro
    Last Post: - 6th October 2005, 05:07
