Using I2C with FullSpeed USB
Results 1 to 16 of 16
    miip 16 bits, 2 bytes. i don't remind how to access to them.. since too much time i don't use them can you refresh my single workable brain cell on this friday before i left home to night club
    D'uh, yeah, bits.
    I just use I2CREAD for a WORD and get all 16 bits in one shot.
    I checked the MicroChip site and they have the MCP23S17 which goes at a maximum of 10MHz in SPI mode. I don't think that's worth the effort to even try.
    But I did get another idea; using a 16F628 to read the MCP23016, sets 4 output pins to a binary value (I just need the number of the 1st active pin) and then sets a READY pin. The 18F4550 works on USB until the READY pin is set and then reads the 4 input pins. TADAA!!! Super fast 16 bit parallel exchange between 2 mcus.
    I just don't know how the 18F4550 can reset the READY pin though. I never got a full grasp of that concept.
    EDIT: Reviewing my own thread from a while ago:
    http://www.picbasic.co.uk/forum/show...ight=busy+line
    mmm, that make me think of few things to try on sunday... i'l do some test with the 4550 and I2C... Anyways i guess that one project i have in head will probably need at least one I2C external device... so i'll hae to mess with I2CREAD/WRITE and/or MSSP anyway.
    Your point is valid but need extra hardware... sure workable, but it have to be done without it. The MSSP is the one i mostely suspect workable. SPI is faster than I2C... but MSSP i2C is more fast than PBP I2CREAD/WRITE
    mmm...
    Steve, I don't have much choice. The SPP feature on the 18F4550 has only 8 bits, I need at least 13.
    I wonder if I can do this with discrete components instead of using the MCP23016 and 16F628 to generate a 4 bit combination. I have 13 momentary push-buttons that I have to get to the 18F4550 as fast as possible.
    I'm sure there's another way. I'll ask on an electronics forum and see what the gurus there come up with.
    Sure it have 8 bits... 2 successive read .. well something like stated somewhere in the MCP datasheet. It must exist a quick drwaing of it somewhere in.
    if you really want to add stuff, 4 choice spring to mind
    use a bigger PIC than the 16F28, then just read the i/o, send it to the 4550 via USART.
    Use a keypad decoder like 74c922
    Use a single (or more) A/D pin of the 4550 with a multi-step voltage divider... yisssh
    Find a multiplexer... time is short now, but it have to exist, i had the 4067 idea... but i'm not sure... i must forget something on this chip.. what? i don't know.
    I like the 74C922 keypad decoder, looks simple enough.
    EDIT: Hmmm, looked simple enough until I saw the prices at DigiKey and Mouser. It's 1/2 the price to go with a MCP23016 and PIC 16F628.
    Steve, the 4067 multiplexer/demultiplexer is even better and only $2.08CAD at DigiKey.
    The only problem is that I don't understand how to get it to go 'backwards'. The A0-3 pins are always referred to as inputs, I need them as outputs. I'm sure there's a way 'cause these are called both names, they must process both ways, no?
    EDIT: "The CD74HC4067 and CD74HCT4067 devices are digitally
    controlled analog switches that utilize silicon-gate CMOS
    technology to achieve operating speeds similar to LSTTL,
    with the low power consumption of standard CMOS
    integrated circuits.
    These analog multiplexers/demultiplexers control analog
    voltages that may vary across the voltage supply range.
    They are bidirectional switches thus allowing any analog
    input to be used as an output and vice-versa. The switches
    have low “on” resistance and low “off” leakages. In addition,
    these devices have an enable control which when high will
    disable all switches to their “off” state."
    It should work.
  1. I2C Master/Slave 16F88/16F767 working code
    Last Post: - 23rd October 2012, 23:31
  2. Simple USB Comms Problem
    Last Post: - 6th January 2010, 21:17
  3. HARDWARE I2C SAMPLE CODE question
    Last Post: - 16th June 2009, 22:07
  4. I2C Master Slave issues.
    Last Post: - 29th March 2008, 20:33
  5. Please help with i2cslave i2c slave
    By cycle_girl in forum mel PIC BASIC Pro
    Last Post: - 1st December 2005, 14:55
