OK so you're having an issue with the example code.
Can you post the code you have, we can then review it for errors or problems?
here is the example code
' SERIN & SEROUT Commands
' Upper case serial filter.
Include "modedefs.bas" ' Include serial modes
SO con 0 ' Define serial out pin
SI con 1 ' Define serial in pin
B0 var byte
loop: Serin SI,N2400,B0 ' B0 = input character
If (B0 < "a") or (B0 > "z") Then print ' If lower case, convert to upper
B0 = B0 - $20
print: Serout SO,N2400,[B0] ' Send character
Goto loop ' Forever
thanks for any help
I would try something like this:
SO var portb.0 ' Define serial out pin <-------You have to define a port
SI var portb.1 ' Define serial in pin <--------You have to define a port
B0 var byte
loop:
Serin SI,396,[B0]' B0 = input character
If (B0 < "a") or (B0 > "z") Then ' If lower case, convert to upper
B0 = B0 - $20
Serout SO,396,[B0] ' Send character <------You don't need print command
Goto loop ' Forever
Try this and see what happens.
Chris
finally the write code for serin\out thanks for all your help
