serin,serout
Results 1 to 7 of 7
Thread: serin,serout
    Jun 2006
    Angry serin,serout
    can any one give me the correct syntax and expressions for serin and serout
    any help would be great
    Jun 2005
    Wisconsin
    This information is in the user manual.
    http://www.melabs.com/resources/pbpmanual/
    Is there something specific you are trying to do that isn't working?
    Jun 2006
    Unhappy been there done that
    that is where the code i am useing came from
    i use 16f84a pics
    microcode studio and pic basic pro
    it is incorect according to microcode
    this is driving me crazzy keep geting bad expresion errors
    thanks andrew
    Jun 2005
    Wisconsin
    OK so you're having an issue with the example code.
    Can you post the code you have, we can then review it for errors or problems?
    Jun 2006
    Unhappy the ofending code
    here is the example code
    ' SERIN & SEROUT Commands
    ' Upper case serial filter.
    Include "modedefs.bas" ' Include serial modes
    SO con 0 ' Define serial out pin
    SI con 1 ' Define serial in pin
    B0 var byte
    loop: Serin SI,N2400,B0 ' B0 = input character
    If (B0 < "a") or (B0 > "z") Then print ' If lower case, convert to upper
    B0 = B0 - $20
    print: Serout SO,N2400,[B0] ' Send character
    Goto loop ' Forever
    thanks for any help
    New Jersey
    I would try something like this:
    SO var portb.0 ' Define serial out pin <-------You have to define a port
    SI var portb.1 ' Define serial in pin <--------You have to define a port
    B0 var byte
    loop:
    Serin SI,396,[B0]' B0 = input character
    If (B0 < "a") or (B0 > "z") Then ' If lower case, convert to upper
    B0 = B0 - $20
    Serout SO,396,[B0] ' Send character <------You don't need print command
    Goto loop ' Forever
    Try this and see what happens.
    Chris
    Jun 2006
    Smile finally the truth
    finally the write code for serin\out thanks for all your help
