Prop clock???
Results 1 to 7 of 7
Thread: Prop clock???
    Jun 2006
    Bangalore, India
    Default Prop clock???
    Has anyone tried making a propellor clock (persistance of vision clock) or something similar using PBP???
    ---Whats a propellor clock?
    --- check this out http://www.bobblick.com/techref/proj...propclock.html
    http://www3.sympatico.ca/surfin.dude...clk/blick.html
    Yup, designed my own clock, s/w done completely in PBP. Mine is quite a bit different from Bob's in that I use a RTC chip besides the PIC (16F628A), IR for control and a brushless DC motor.What specific information are you looking for?
    Anand
    Jun 2006
    Bangalore, India
    Smile
    Could you post me your code and schematic please???
    I wrote a code in ASM but couldn't add remote cause it got a bit too complex for me...
    Jun 2006
    Bangalore, India
    Question Help Please !!!
    Hi ardhuru,
    I just wanted to look at your code so that i could learn how to keep the time printing process un-interrupted while reading the real time clock IC...
    I wanted help on the rotating transformer also...
    Hi ShahidAli,
    * *I just wanted to look at your code so that i could learn how to keep the time printing process un-interrupted while reading the real time clock IC...* *
    My clock does not have an analog mode, so the coding is easier. It has 2 frames; the top half for calendar and the bottom half for time. The first frame (time) starts displaying immediately after the index pulse. After the last digit of this frame (unit seconds) is displayed, you have enough time to read the RTC, before you need to start displaying the calendar.
    The rotating transformer turned out to be easier to build than I thought; I used 100 turns for the primary (fixed), and 125 turns for the secondary (roatating) coil. The primary, 12 volts pulsed at 32 khz, around 55% duty cycle worked well for me.
    Anand
    Jun 2006
    Bangalore, India
    Post
    Hello again ardhuru,
    Could you help me with the transformer drive circuit???
    Here you go...
    Anand
  1. Single digit 7 Seg LED clock - PIC16F88
    By thirsty in forum Code Examples
    Last Post: - 17th July 2009, 09:42
  2. UberNewbie can't set his clock...
    Last Post: - 7th January 2009, 05:22
  3. EM4095 Chip, get Clock and Data signals?
    By mindthomas in forum mel PIC BASIC Pro
    Last Post: - 19th August 2008, 07:27
  4. Shiftout/in
    By BobEdge in forum mel PIC BASIC Pro
    Last Post: - 23rd August 2007, 12:48
  5. Help with sound command in 2 programs
    Last Post: - 5th July 2007, 21:36
